Old 09-04-2018, 11:12 AM
paintpollz's Avatar
paintpollz paintpollz is offline
Boat: 2002 Prostar 197
02 prostar replacement steering column
Can anyone confirm if this is the new steering column for a 2002 197? I've got some play in the steering wheel and rattles like mad out of the holeshot. It helped a little when I got my prop balanced, but still is pretty bad.
https://www.ebay.com/itm/SeaStar-Spo...ox!76107!US!-1
Thanks!
Kevin
Old 09-04-2018, 11:43 AM
woodrowskis woodrowskis is offline
Boat: 2015 Prostar (previous boat 2002 197)
I did have similar play in my '02 Prostar 197. I first noticed slop probably around 2011 and replaced in 2014. I replaced the tilt assembly and it did fix it. so I think you are on the right track. I bought my tilt replacement from skidim but I think I recall they don't have it any more. I do not think mine was by "Sea star" but (1) I might be wrong and (2) it may be a copy that works. I don't recall the component looking like that. Does anyone know if Sea Star copies Teleflex equipment?
Old 09-04-2018, 01:57 PM
paintpollz's Avatar
seastar is teleflex, i think it's the same.
thanks
Kevin
Old 09-04-2018, 11:33 PM
paintpollz's Avatar
Wheres Mike G When U Need Him!
Kevin
Old 09-05-2018, 07:34 AM
Fullpass's Avatar
Fullpass Fullpass is offline
Seems like you can get the complete unit for about 30/40 bucks more, everything might match/fit better. Have play in part of your unit/possible more elsewhere. I will be updating mine also, if your thinking about updating your steering wheel you might go with the splined version.
Old 09-05-2018, 10:46 AM
paintpollz's Avatar
Do you know what the item numbers are? I do not want to get a new steering wheel.
Are you having similar symptoms? It ruins the driver experience, the vibration/shaking is awful out of the holeshot.
Kevin
Old 09-05-2018, 10:59 AM
88 PS190 88 PS190 is offline
I have a worn out tilt thats very sloppy but it doesn't seem to do that at holeshot.
Usually the wheel itself has a hub, that hub has a standard bolt pattern that allows you to get a splined vs. keyed hub. My 94's helm is a splined hub I would assume the same out of yours?
Old 09-05-2018, 11:07 AM
paintpollz's Avatar
This is good info, because now it leads me to believe that it is once again prop related. Must just be an old prop that has been worked on too many times and has gotten out of balance again.
i think mine is splined
Kevin
Old 09-21-2018, 10:13 PM
46Chief 46Chief is offline
Could be prop, shaft or flex plate.
