Hi there, just wanted to post this incase it helps anyone and also as for some help myself.
My 2008 X2 runs in seawater and all the steel bolts on the aluminum tower have seized up. I thought it was near impossible to get anything loose without drilling and tapping the bolts which was something I would probably screw up but I had some success.
So my boat cover needs replacing and I thought it would be worth trying to unseize some of the bolts so I may fold the tower and get a cover that covers the whole boat to keep it nice and clean when not in use, I started at the rear feet trying to remove the bolt there, the knobs both come off but I'm left with 2 studs on each side, in which case I screw in 2 nuts and lock them together to give me something to turn. I managed to snap the stud on both sides initially as it simple would not budge and I used too much force. I decided to remove the tower feet from boat, and separated them from the tower which was quite easy hitting them with a hammer as the tower part is not threaded. With the tower feet off I tried heating, waxing, oiling, acid and every combination to try and free the stud with no luck. What finally worked was simple heating the aluminum around the stud and hitting it with a hammer all around the stud, and using an impact driver to turn the stud which eventually got them free. It was not easy but I feel so lucky I can now get the rear part of the tower folded and I just wanted to share this incase anyone thinks it's impossible.
So the next step is the front arms of the tower in the below pic and this is where I would like some help. I'm assuming that these are also bolts that are supposed to come off with the knob? Or are they studs that slide through when the knob is removed? I haven't wanted to put too much force on them yet so thought I would ask here first.
