  #71
Old 11-06-2017, 12:46 PM
2gnospam 2gnospam is offline
Boat: Mastercraft, Prostar 190, 1987, Indmar 351
Thanks for the info and I will check with Viper. Do you remember if the new material for the channel part is hard plastic or aluminum?
Through some other reading, I believe the original rail is from TACO:
http://tacomarine.com/product/A11-03...minum-Rub-Rail
They do not sell a black anodized version. They have a hard rubber version that is black but is slightly taller at 1.25"
Thanks again.
Old 11-06-2017, 01:10 PM
Luv2Ski's Avatar
Luv2Ski Luv2Ski is offline
Boat: 1988, ProStar 190, 351w
The outside is a harder plastic while the interior is more of a firm rubber. No metal involved other than the screws. It sounds like I may have the version you mention as height was a factor that precluded putting on the factory seam cover back on. I suspect a metal version (particuarly black) would have looked slighly better, but in general the plastic is holidng up just fine.
One tip, I did have a bit of a leak that would drip down next to the driver foot well. Turned out to be from the rubrail which was not put on with any silicon. I put a small bead of clear silicon under the rail and the problem was solved. Also, heating up the interior portion makes for an easier installation.
Old 11-06-2017, 02:30 PM
Great. Thanks for the info.
Old 11-06-2017, 02:41 PM
I may look into powder coating or anodizing the original rail.
Old 11-27-2017, 07:28 PM
Luv2Ski,
Is the lightest color of you interior white or a light grey?
Thx.
prostar 190, restoration, vinyl
