Old 08-18-2019, 09:11 PM
Baron515 Baron515 is offline
Boat: 2008 X2
Seized ZFT3 tower
Hi there, just wanted to post this incase it helps anyone and also as for some help myself.
My 2008 X2 runs in seawater and all the steel bolts on the aluminum tower have seized up. I thought it was near impossible to get anything loose without drilling and tapping the bolts which was something I would probably screw up but I had some success.
So my boat cover needs replacing and I thought it would be worth trying to unseize some of the bolts so I may fold the tower and get a cover that covers the whole boat to keep it nice and clean when not in use, I started at the rear feet trying to remove the bolt there, the knobs both come off but I'm left with 2 studs on each side, in which case I screw in 2 nuts and lock them together to give me something to turn. I managed to snap the stud on both sides initially as it simple would not budge and I used too much force. I decided to remove the tower feet from boat, and separated them from the tower which was quite easy hitting them with a hammer as the tower part is not threaded. With the tower feet off I tried heating, waxing, oiling, acid and every combination to try and free the stud with no luck. What finally worked was simple heating the aluminum around the stud and hitting it with a hammer all around the stud, and using an impact driver to turn the stud which eventually got them free. It was not easy but I feel so lucky I can now get the rear part of the tower folded and I just wanted to share this incase anyone thinks it's impossible.
So the next step is the front arms of the tower in the below pic and this is where I would like some help. I'm assuming that these are also bolts that are supposed to come off with the knob? Or are they studs that slide through when the knob is removed? I haven't wanted to put too much force on them yet so thought I would ask here first.
Old 08-19-2019, 02:10 AM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
The screw is supposed to come out with the knob. Can you remove the oval shaped part and pull it off the threads? Be careful not to snap the hex heads off the screws. If you can remove it, then I suggest using some of this on the threads.
Kano Aerokroil
Spray it on and let it sit for a day. Then put nuts on the threads and tap around them with a hammer. Then some more oil. Use 2 nuts on the thread as you described to get some leverage and try to remove it.
If it comes out, make sure you put anti-sieze on the threads before you replace the bolt.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Ballast Timer Reprogramming Info
Old 08-19-2019, 03:44 AM
Boat: 2008 X2
Thanks for confirming that.
The Allen keys are seized too.
What exactly does it screw into though? Doesnt seem I would be able to heat up the thread area. Any chance someone has a picture of it opened up?
Old 08-19-2019, 05:06 PM
Boat: 2008 X2
I got them loose!
Now to replace them and reinstall the back legs and all should be well!
Heat was the solution again. I heat around the area of where the threads should be and just took it slow.
Old 08-19-2019, 05:13 PM
Elberoth's Avatar
Elberoth Elberoth is offline
Boat: 2007 X2 350 MCX
Originally Posted by Baron515 View Post
I got them loose!
Did you heat the bolt as well ?
Old 08-22-2019, 09:36 AM
Boat: 2008 X2
No, I only heat the tower to try and expand the aluminum threads but not the stud. I did also spray it with some penetrating oil when hot to try reduce the friction. I then had to reheat the aluminum and only tried to turn it when it was at its hottest, I got it to turn about an 1/8 of a turn and then I would tighten and loosen for that 1/8 turn until it felt loose and try to loosen further.
