  #241
Old 09-05-2017, 09:32 AM
also looks like part number is css067 now but Lada parts is Crankshaft Sensor 2112-3847010-04
Old 09-05-2017, 01:13 PM
SmithX30 SmithX30 is offline
Boat: 2019 Xstar
Thank you both. Sorry about the link I am not sure what happened. In an earlier thread it looked like gsxrjtt found some that had a part number of 556036SR on the bags. These looked OEM. I didn't see if he was able to get these to work, and if they did, do you know if these will also work for an LTR? I think I may have found some, is why I am asking. The first portion of the numbers, DR6123, are the same as mine, but the last numbers are not 6111 they are 1273. Do these last four numbers have any bearing? They look identical to the ones I have removed and state they are for an LT1 or LTR motor. I tired to attach a picture of the ones in gsxrjtt previous post. Thanks again for all of the help!!
Old 09-05-2017, 01:28 PM
they should work - the ignition system is the same on LTR as the LT1...
Old 09-05-2017, 02:45 PM
Boat: 2019 Xstar
Thank you again, just ordered 4 of them. I appreciate all of the help!
Old 06-03-2018, 07:35 PM
john jones john jones is offline
Boat: 2002 Xstar
I am looking to order a few back ups for my 02 X-star 330 LTR. I want to be sure to order the proper ones. Do I need to double check a part number on my motor or will the last provided link be the right part?
Thanks
Old 06-03-2018, 08:47 PM
Last link should point to cps' for a Lada.. on aliexpress
Old 06-03-2018, 10:09 PM
Boat: 2002 Xstar
Mike,
Thank-you!, I saw so many dead links and different ones that I wanted to be sure before ordering. I just put in an order for 2.
John
Old 06-04-2018, 12:20 AM
Originally Posted by john jones View Post
Mike,
John
I would get 4 they are cheap and keep the reluctor wheel in good shape - aka now rust - clean and shiny - along with good clean connections
Old 09-13-2018, 03:24 PM
TechnicalServices's Avatar
TechnicalServices TechnicalServices is offline
Boat: 1996 Prostar 190
Technical services sells these sensors on Ebay
https://www.ebay.com/itm/121698981995
Old 06-02-2019, 05:37 PM
MCChris MCChris is offline
Boat: 2008 MasterCraft X-Star 400hp 6.0 Ly6
Does anyone know where to find the harness for an ltr 330hp from the crank position sensors to the coil pack? I some how lost mine.. and can not find it anywhere online. H1473 is on the harness
