I need some help. I have a 94 maristar 225 VRS that starts right up and idles perfect. But when you throttle it it dies almost immediately. Out of gear you can get some rpms if you rev it very slowly but put it in gear and dies just barley above lidle.
So far I have
Changed both fuel filters and cleaned the tank
Changed the IAC valve
Changed the map sensor
Changed the TPS
The fuel psi at the rail is 38 at idle and when it dies and with the fuel psi regulator unhooked it’s 43 psi wind still dies.
So far I have
Changed the TPS
