Old 06-18-2019, 11:17 AM
Maristar210's Avatar
Maristar210 Maristar210 is offline
Boat: paddle
I hate to ask but is the throttle lever pulled out?
Old 06-18-2019, 12:51 PM
Jwgredeux Jwgredeux is offline
Boat: Mastercraft Maristar 210 vrs
Not sure I know what you mean. We were accelerating up to 10.7 where I had perfect pass set. So I was moving the throttle down to accelerate.
Old 06-18-2019, 01:03 PM
Boat: paddle
The base of the throttle pulls out towards you so you can rev the motor without it in gear. Or hell they used to anyways...
Old 06-18-2019, 01:19 PM
Ah. So mine has a button in the center of the base of the throttle shaft that has to be pushed in if you wanted to rev the motor out of gear. It was not pushed in and we had been riding/surfing for a while before the incident.
I did shut the boat off and restart after and still had the issue. I did not actually push the button in and off again to double check. It would be embarrassing and a relief if that is the issue.
I went ahead and dropped off at my local shop this AM to get it back as quick as a can so we don't miss too much of the season.
Old 06-18-2019, 01:34 PM
Boat: paddle
I've done it by accident is the only reason I thought of it. Might go there first before they start looking at the linkage & cable.
Old 06-18-2019, 05:42 PM
88 PS190 88 PS190 is offline
Have the work through - start at the linkage, if the linkage is good and based on description I'd be thinking about the flex disc.
Old 06-18-2019, 09:12 PM
mtajpa's Avatar
mtajpa mtajpa is offline
check this nut on the trans coupling. Should be tight and the coupling should turn when the prop is turned. May have sheared the key inside coupling. Or the damper plate failed.
99 MariStar 230 Sport LTR 330
Old 06-19-2019, 01:50 PM
Shop told me they took a quick look at everything, and based on a quick inspection everything looked and moved as expected. No loose or missing bolts, pins etc. So they hope to get it in the shop tomorrow and go through it fully and see what we are dealing with.
Makes me think it is something with the pressure, fluid was full and good.
Old 06-25-2019, 05:35 PM
Talked to the shop. They said the drive plate had failed. Sounds like the guys that said flex disc or damper plate were talking about the same part?
Quoted 250ish for the part but over 1300 for the labor to install, as they have to pull out the transmission and rebalance everything? Ouch.
