Old 06-18-2019, 12:21 PM
dbatteiger's Avatar
dbatteiger dbatteiger is offline
Boat: 1993 prostar 190
Brass or Glide bushings
(93 Prostar 190) I just put in a set of Brass/neoprene bushings last weekend. Then I found glide bushings for a strut that's 1.375 OD which mine uses. Skidim only had Brass for that OD size. I am so tempted to go ahead and put the Gilde bushings in to see if there's a difference. I know I will have to sacrifice the new ones. Wife says "I don't get it, you just put those in" Wrenching part is easy. To do or not to do? Can I get some feedback from those of you that have switched to vesconite bushings from the old Brass morses?
Old 06-18-2019, 01:24 PM
Strreamline Strreamline is online now
Boat: 1988 Mastercraft Platinum Prostar 190
I changed mine to glide when I bent my shaft last fall. Haven't noticed any difference at all, and my original brass ones lasted around 30 years...if it were me, i wouldn't bother cutting out perfectly good brass ones just to switch to glide.
Old 06-18-2019, 01:34 PM
EricB EricB is offline
Boat: 77 S&S, 1983 S&& PS, and now a 98 Anniversary S&S LT1 PS
I agree with Strreamline...it's done already, so change to glide when it wears out.
Old 06-18-2019, 04:41 PM
+1...I have used both makes. Nothing earth-shattering between the two.
You'll get 10 years plus out of those bearings. Listen to the wife.
FYI...OJ Props sells the nylon inserts.
John 14:6
Old 06-18-2019, 07:34 PM
Maxirat427's Avatar
Maxirat427 Maxirat427 is offline
Boat: '14 X30 6.2L, '96 SkiRay Tournament(sold)
Wouldn’t waste the money. You’ll never see a difference. By the way, my strut bearing is 23yrs old and its made if hard rubber.
There may be better ways to relax than being on a boat...I just haven't found one yet!
Old 06-18-2019, 08:38 PM
ahhudgins's Avatar
Boat: 79 S&S. 87 Prostar Powerslot. Present 95 Maristar 200VRS
What? No increase in HP or top end speed???
Old 06-18-2019, 10:21 PM
dbatteiger's Avatar
Bushings
Thank you all for chiming in. I put my vesconites "In stock" for the next go round on shaft or bushing maintenance. Rolling with my new Morse's. My boat is the first picture you see when you bring up Skidim website. I did something different on gland nut this time. I disregarded drip rate and went solely by temperature. I would run it and stop and feel it. One flat makes a big difference in temp. I am 20 degrees warmer than the water running at 3,000 rpm. Its warm but won't burn you.When I pulled the shaft to do my bushings I had a little wear at cutlass spots but not critical. What I was amazed at was the shaft where the packing rope seals was worn a bit. Hard to believe rope can do that to stainless bar. I was probably to lean on drips when said and done.
Old 06-19-2019, 07:19 AM
93Prostar190's Avatar
Go ski!
Sent from my iPad using Tapatalk Pro
Ski in snow, ski in water, and always have fun!
2008 Prostar 214 MCX
1995 Prostar 190 "Evil Minion"
"Do you have Flake on that boat?"
