2012 was the year they got rid of programmable timers, so unless you have the plug'n'play option, it's going to be a little difficult to have the stock ballast system fill additional ballast. Work arounds were getting the medallion programming tool to modify the software to run longer, install extra ballast pumps hardwired to relays and added switches, or you can rewire the existing ballast pumps to hardwired switches. I did the last one, but there are a few tricks to get the system to work correctly. I can give you more info on any of the options if needed.
In addition to seeking advice here, you should give the guys at Wake Makers a call. They know their stuff, and can tell you exactly what parts you need to get it done. If any of it sounds over your head they can explain it, and if you don't feel comfortable doing it yourself you can have a dealer do the work but at least you'll have an understanding of what's being done.
2012 was the year they got rid of programmable timers, so unless you have the plug'n'play option, it's going to be a little difficult to have the stock ballast system fill additional ballast...
Here are some threads on 2012 ballast pumps. The first one has 3 additional links going through the issue/options. The second one is the programming option.
I don't understand your current software comment. 2012 was a one off year. In 2013, MC switched from medallion to Murphy, so you can't have the current production software in your boat.
I'm sorry, I am confused on this too.... our boat dealership says they "updated our software" so we no longer have the 2012 software, they say it's "current." But I have been told that 2012s software are changed to 2013 software? Does this make any sense?
Does your screen have push buttons in the metal surrounding it or is the metal frame around the screen solid?
They may be meaning that it has the most current updates which is good. But even with the updates you cant piggy back of the system easily like you can with the 2013-16 Murphy Systems.
I'll save you some headache and tell you that you don't need or want 1000lbs in each corner of your X25. Plumb those XStar sacs in and you'll be good to go. Your additional weight will go into port/starboard coffin seating and some in bow opposite surf side.
