Old 06-23-2014, 03:40 PM
Sloz06 Sloz06 is offline
Boat: 1998 sport star LT1
Question Water in oil LT1 1998 Pro Star
Here is the scoop,
I put the boat away last fall, winterized it as normal. ( but did not change the oil)
I was changing the oil this spring and before changing the oil I checked the dip stick, and there was a significant amount of extra"oil".
I did not run the boat, and drained the oil, I captured the first oil that came out of the pan in a clear container only about 1/2 inch in the bottom of a 1 gallon container was clearish, The rest was a very thin liquid/oil. In all it seemed to have about a 1/2 gallon of extra oil.
I changed the filter replaced the oil, ran it for about an 15 minutes drained the oil again, which showed signs of water "foamy" then drained the oil and filled it up fresh one more time.
I have ran the boat for about 45 minutes and it does not seem like the oil level is raising.
Has anyone had similar issues, does this sound like a head gasket. Can I run the boat for the summer "checking the oil constantly of course"
Any one have experience with changing head gaskets, could the water be coming in through the exhaust cooling system.
"Tubing is for fat kids"
1998 Pro Star 190, LT-1
Old 06-23-2014, 03:55 PM
mgs96ps mgs96ps is offline
Banned
Boat: A
Old 06-23-2014, 04:08 PM
have you ever inspected the exhaust manifolds and risers by taking them apart?
16 year old boat - should inspecting annually now. very easy to change if needed. Are your manifolds and risers rusty - post a pic.
Old 06-24-2014, 04:12 PM
I'll Take a look when I get home from work and post a picture, there is definitely rust to my recollection at the manifold bottoms.
How would this get water into the oil though?
Thanks,
Old 06-24-2014, 05:06 PM
Thanks,
might be getting a little water intrusion or the trans cooler has a slight leak
Old 06-25-2014, 09:33 AM
I have not taken them apart yet, I am going to order the gasket kit from "discount inboard marine" It was a bit to dark to take pictures but the manifold bottoms are definitely rusty.
Any tricks on getting the 2 rear Allen bolts out of the riser? My allen socket would not fit.
once off, what is the best method to test the or manifolds, or could it be the gaskets those looks pretty ****ty from the out side.
Old 06-25-2014, 09:40 AM
you have to take an allen wrench and cut it down.
Old 06-25-2014, 10:24 PM
Or get a ball-end allen wrench.
aluminum heads, foamy oil, head gaskets, lt1, oil in water
2020
