Old 07-21-2016, 12:59 PM
MC FEVER's Avatar
MC FEVER MC FEVER is offline
Boat: 93 Prostar 205 LT1
Originally Posted by CrazyTruck View Post
Hi Jmshelto. I should have a P5000 being delivered today. Let me take a look and feedback on if it'll work and how best to plumb it. Since it's a spare, I won't actually be installing it, but hopefully after physically looking at it, I can better answer your questions.
Look forward to your posting. I'll be in the market for a spare pump soon for my LT1.
- I'd rather be SWERVING!
Old 07-22-2016, 12:31 PM
CrazyTruck CrazyTruck is offline
Boat: 1995 Prostar 190, LT-1, Powerslot
So I had a chance to look at this. It looks like it'll work.
  • Power Connector: The same as existing - No issue
  • Fuel Inlet Connector: Comes with a 3/8" hose barb adapter, so you'll need to remove the swivel currently on the fuel line and direct connect - No issue
  • Fuel Output Connector: Comes with an adatper for 3/8" hardline, which is what is there - Should work
  • Actual Pump: The pump itself looks almost identical to the original, short of having a different input and output configuration
For the return line, you'll just need to get the parts to remove the T in the line. I believe it's a 1/4" FIP T, but again, this is a spare, so I haven't pulled it apart yet to see. You could replace it with a female-female coupler or remove all the other connectors/adapters and try to go from the hard line to the hose. The hardline has a double flare brake line nut on it, but I plan to use the existing adapter (to IPT) and go directly from that to a 3/8" hose barb to keep things clean.
Hope that helps. I'm guessing I'll need to replace this when the boat goes out to Lake Powell early Sept, so I can give you more info then (if you can wait).
Old 07-30-2016, 03:49 PM
Lbferguson Lbferguson is offline
Boat: 1995 ProStar 190
Prostar 190
Have 1995 looking for new speedometer pickups Saw old post that new ones are 3 holes we now have 2
I assume if 21 years old we should replace the tube also - Is there a particular brand people are buying or does it go by brand of speedometer ?
Thanks great information you've posted.
Next step we downloaded templates and going to try to cut new decals will let you guys know.
Old 07-31-2016, 10:25 AM
skidim has this kit.. I did not drill and extra hose..
http://www.skidim.com/TOURNAMENT-PIT...ductinfo/769B/
http://www.skidim.com/TUBING-SPEEDO-...tinfo/5100632/
I did both and ran all you hose..
Old 07-31-2016, 10:50 AM
1995 Prostar 190 Decals
Sorry posted in wrong thread Not sure how to delete
Old 08-01-2016, 11:56 AM
@mikeg205 - I thought you already had some decal templates put together?
BTW, on the fuel return brass tee - I now think it might not be 1/4" FIP, but rather something smaller. If anyone has one or is motivated to disassemble and check, let me know. I have a spare piece that goes into the fuel pump, so I'm looking at getting a cap for that in case I have to do a field repair with the new pump.
Old 08-01-2016, 12:01 PM
BTW, on the fuel return brass tee - I not think it might not be 1/4" FIP, but rather something smaller. If anyone has one or is motivated to disassemble and check, let me know. I have a spare piece that goes into the fuel pump, so I'm looking at getting a cap for that in case I have to do a field repair with the new pump.
Yes - templates in the library
Old 08-10-2016, 01:24 PM
MC FEVER's Avatar
I think I may look into going this route. Pump is starting to hum a little bit. Looks like I've got an off season project....
Old 08-23-2016, 07:00 PM
Dukee Dukee is offline
Boat: 1994 Pro Star 20.5 Indmar Engine 350 Chevy block
Dukee
Looking for fuel pump Indmar 554016 or Carter P60962. Any suggestions or replacements. Need some suggestions if any
Old 08-23-2016, 07:06 PM
those are gone!
2 options... indmar 49-5117 http://www.marinepartssource.com/new...&mfgno=49-5117
or
this
carter p61171 https://www.summitracing.com/search?...arter%20p61171
both require a little rebplumbing
or you can got airtex e2044 and make an in-tank pump.
lt1, powerslot, prostar 190, ps190
