My 1993 190 Prostar with a 351 Ford Indmar was operating just fine. Warmed it up at the dock... shut it down... came back... turned key... nothing. No click... no gauges... nothing. I started working from the battery switch to the breaker behind the block... both good. I had power to all 4 posts on the ignition... but I replaced it anyway... no change. Ignition breaker on the dash panel has not tripped... what am I missing. Thanks!
Baffled with electrical issue
I would start with cleaning the main battery cable connections.Remove and clean each with a wire brush. Don't forget the block ground....it's the most likely cause.CUSTOM WHEEL & TIRE PACKAGES
sigpic
Email - [email protected]
50 amp Breaker
Thanks for your reply.. I will check the ground.
I have read several posts that talk of a 50 amp breaker... there is a 15 amp breaker mounted just aft of the block on the plate where there is a battery switch... it was fine but I don't know where to look for a 50. Any thoughts? Thanks!
