Old 11-11-2018, 06:53 PM
vtjballeng vtjballeng is offline
Boat: Mastercraft, skier, 1981, 351
What is the K&N Filter cross for Indmar Part# 525022 or S525022?
A few searches here didn't reveal the answer. Upgrading the Flame Arrestor to K&N Filter / Flame arrestor. Not sure on PN for my LTR 330 equipped 1999 Prostar 205v.
Indmar Part# 525022 or S525022 seems correct
https://www.bakesonline.com/air-filt...y-engines.html
Anyone know the K&N cross number?
https://www.knfilters.com/marine/boats.htm
Are there other filter / flame arrestor options?
Got mine with 870 hours, 3 prior owners, and a THICK coating of oil & sludge on throttle body and presumably in the intake. Will be disassemblying & cleaning but would like to keep it clean going forward.
Old 11-11-2018, 07:02 PM
John 14:6
Old 11-12-2018, 09:43 AM
lav's Avatar
lav lav is offline
Boat: mastercraft,2002,x star,5.7L indmar
Not sure if it's the same,
I have 2002 Xstar 5.7l indamar I run K&N HP 3002
I think most people on here run Napa Gold if I remember correctly so prob won't see much feedback
Hope this helps
If it wasn't dangerous it probally wouldn't be fun.
Old 11-12-2018, 11:06 AM
Table Rocker's Avatar
There should be a number on the back of the flange that is the K&N number.
Here is the list of K&N marine arrestors:
'96 ProStar 205 SD LT-1
Old 11-13-2018, 12:43 AM
lav's Avatar
lav lav is offline
My bad I didn't read that at all for some reason missed flame aresstor
Old 11-13-2018, 02:00 AM
gweaver gweaver is offline
Looks very similar to K&N 59-5023. From the Bakes website, I used the 525023 Mfr number, ran that through Google and got several hits for the 59-5023 flame arrestor.
Search of the K&N website shows listings for Indmar engines. They have a number 59-5020 which looks very similar, but has a molded in curve.
Hope that helps.
G
Old 11-13-2018, 10:10 AM
Yours was coated with oil because the previous owner or whoever serviced it didn't clean it. These all collect that stuff and the easy answer to "How do I keep it clean?" is to clean it annually. You should be able to spray carb cleaner in from the back or set it in a pan with gas or mineral spirits for long enough to make the stuff come off. I use clean gallon paint cans from Home Depot to soak parts but I'm not sure this will fit through the top. Maybe if you tilt it as it goes in....
