Originally posted by CantRepeat
View Post
Throttle Position Sensor Bad on 2006 star MCX
Same issue for me this year. 2006 x2 mcx. Boat would random rev at idle. Makes for interesting dock. Lol. Pulled switch at helm, opened, cleaned with contact cleaner, reinstall. Thanks Sodar for posting the pic of the backside. Be carful opening the switch. Spring came loose on me and was fun figuring out. I got scared and ordered another from Mouser like others but actually installed the old one once I figured it out. Passed garden hose test. Lots of great people here. You all saved us $1000. Dealer quote. Thank you!
How did you remove the actual sensor? The one pin going into from the throttle arm seems to have a fancy small clip holding it in place on the inside of the sensor. I have the old sensor taken off the throttle with the little gold arm still attached to it. The sensor is disassembled in half....I was wondering if there is a way to prevent having to open up the new sensor I ordered when it arrives.
The spring came out of the old one on me...not sure how it goes back together now or if it even matters how the spring is positioned.
Originally posted by mreed0167 View PostHow did you remove the actual sensor? The one pin going into from the throttle arm seems to have a fancy small clip holding it in place on the inside of the sensor. I have the old sensor taken off the throttle with the little gold arm still attached to it. The sensor is disassembled in half....I was wondering if there is a way to prevent having to open up the new sensor I ordered when it arrives.
We have a 2007 xstar and the throttle was intermittently working and the check engine alarm would go off every time we started the boat. I took it to the dealer and they said it was probably the throttle position sensor but we would have to replace the whole throttle ($600 for just the throttle!). My husband found a thread here that someone posted that they took apart the facade, took the sensor out and cleaned it, and it had ran fine for them for 3 years. My husband did the same thing and our boat has now run great since without any alarms going off!! I would try cleaning the sensor before replacing it! If you need the part number (which I don't know if it will be the same for you due to the difference in year), there is a thread somewhere here that has it posted. It was under $60!
Motor compartment. Rear of the motor. Under the ECM where the main breakers are.
I am in need of this sensor I have been waiting for 4-5 weeks for the part. They are trying to sell me the entire throttle and handle assemble. I know there has to be some regular tps sensor that will work. I tried mouser electronics. they are on back order til mid September. I find it hard to believe that it is some unique sensor
I am reviving this thread because I think I may be having this problem. I have an 05 1997 TT with the MCX. The boat is new to me so no previous experience with it with regards to this. Took the boat out a week ago. We ran it around for about and hour and it ran fine the whole time. I didn't notice any surging or idle issues. We were at the dock after about an hour of run time. After a restart it alarmed, and flashed Check Engine on the Diagnostic screen. I shut it down and restarted, same thing again. Looked things over and tried again, this time no issues and we continued for another hour or so with no problems. Took it to the local boat shop (non MC unfortunately but we don't have one here). He says it is giving a "Throttle Code" and is looking into something to do with the throttle control. I posted this on a new thread, but have now stumbled on this thread. I'm going to find out what the code number was, but I'm curious if anyone had a similar experience to mine with no real symptoms other than the alarm and warning. I'm going to mention this to our service tech in the mean time and see what he says. Any further info you guys have would be much appreciated.
QuinnGiddy Up!!!
I replaced mine with the mouser part. hardest part was taking the side panel off. Now I have it all back together, put the boat in and getting error 81 using a mercury scanner it appears to be TAC. Also I had no throttle at all at start up prior to the chk engine light going on. Any thoughts?
Well, I had our mechanic look into my problem, and after a lengthy back and forth with MC and another shop they flashed the computer. It now has something call "checksum 371A" loaded. Took it out for a couple hours, and no more codes or alarms. We'll see how long it lasts. I'll keep you posted.
QuinnGiddy Up!!!
Originally posted by seth1776 View PostI replaced mine with the mouser part. hardest part was taking the side panel off. Now I have it all back together, put the boat in and getting error 81 using a mercury scanner it appears to be TAC. Also I had no throttle at all at start up prior to the chk engine light going on. Any thoughts?
There are manuals in the dropbox - link can be found in the general topic category.sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
Originally posted by SilvrSurfr View PostWell, I had our mechanic look into my problem, and after a lengthy back and forth with MC and another shop they flashed the computer. It now has something call "checksum 371A" loaded. Took it out for a couple hours, and no more codes or alarms. We'll see how long it lasts. I'll keep you posted.
Quinn
A checksum or hash sum is a small-size datum from a block of digital data for the purpose of detecting errors which may have been introduced during its transmission or storage. It is usually applied to an installation file after it is received from the download server.-Tim
