OK.
1996 205 LT1
Noticed the boat starving fuel when the tank was about 1/4 full. Fuel pump was loud
Cleaned all lines, replaced high pressure filter and clear screen on the bottom of the pump and the bottom of the tank tube.
Put some Ethanol free 87 in it. Put it in the water. It run the best it has ever. It reached 5000 rpm with no hesitation.
After about an hour the pump was loud again and I could only get to 4000 rpm.
I want to put a water separator filter inline between the tank and pump.
Will I need to install a low pressure booster pump?
Any suggestions will be very helpful
Also.
Can someone point me to the lowest price for the lt1 fuel pump. I wonder if they are made of Gold.
1996 205 LT1
Also.
