Old 08-23-2018, 10:48 PM
gt23's Avatar
gt23 gt23 is offline
Boat: 2015 X30, 2008 X15 (sold)
Originally Posted by kwoody51 View Post
Not hard, just measured the widest part of the holes and narrowest part this then allowed them to know the center.
I did have to make sure they used 3.5” as I needed that for clamping ‘right’ thur the hull. The 1st unit they sent was 3” expanded out to 3.5” but I couldn’t acces the 3.5” part to clamp.
Moose - I don’t notice any issue at slalom skiing speed. I did loose ~3 MPH so now topspeed is about 40 whereas it was 43 before.
Curious. Lost top speed by 3 miles. Drag or exhaust back pressure?
Sent from my SM-N950W using Tapatalk
Old 08-23-2018, 11:50 PM
jackpita jackpita is offline
Boat: 2008 X14. Sold Maristar 210, 1992, 351
Send a message via AIM to jackpita Send a message via Yahoo to jackpita
FAE available
Fresh Air Exhaust off my X14/214
1 Piece T, MC Flat exhaust, Teak Platform, Quick Disconnect. 555 new, asking 400 plus shipping. PM and I will send exact measurements from my boat that FAE used to manufacture the FAE. Will also send directions for you to measure to ensure it will fit correctly. Only pieces you will need are the cork gaskets that go between the hull and the FAE mount. Removed from my boat since I no longer need to surf behind it. Surf behind a buddy's X30 and ski behind my X14.
Old 08-23-2018, 11:56 PM
kwoody51 kwoody51 is offline
Boat: '08 X14
No idea...
They have a video on their webpage that suggests that the water actually creates a Venturi effect (vacuum) and helps pull out the exhaust.
I imagine this is true but perhaps at higher speeds there is additional back pressure.
While I don’t like loosing the top speed I LOVE all the other benefits.
Old 08-23-2018, 11:57 PM
Boat: '08 X14
Nice hijack...
Although for someone with an x14 a good deal.
Old 08-24-2018, 12:05 AM
Fae
Wasn't an intentional hijack. Sorry. Hindsight being clairvoyant (what they teach us at the Navy War College) I shouldn't have done it. Again, sorry, will make a formal post.
Old 08-24-2018, 12:31 AM
Boat: '08 X14
It’s all good and perfectly fine... Just busting your chops!
If someone with an X14 is checking this thread out then it’s a good place to plant the seed.
Old 08-25-2018, 10:02 PM
mike koen's Avatar
Where do I find their web site ? I need to source all this out . Thanks !!
If she don't shine , she ain't mine
Old 08-25-2018, 10:48 PM
mike koen's Avatar
Kwoody I believe I found the site. Is your FAE system mounted to your swim platform or brackets ?
Old 08-25-2018, 10:51 PM
Boat: '08 X14
Hull mount - 1st post 1st pic is how it looks finished, no other brackets!
I went for the factory look .... at 10x the effort to install!!!!
Old 08-25-2018, 11:05 PM
Sbrelje Sbrelje is offline
Boat: 2006 x15
Either email or give them a call and tell them your boat year and model and ask them about the hidden mounting options. Kwoody51 has the thru hull and I have the drain plug. I'm guessing they don't advertise these options because they won't work for all makes and models but their customer service is awesome, so if you ask for something better than the standard they will most likely deliver!
Sent from my SM-G960U1 using Tapatalk
