Interesting: I switched to electronic ignition a few years ago (ballast resistor removed)
Neutral safety switch
Originally posted by Wouter View PostInteresting: I switched to electronic ignition a few years ago (ballast resistor removed)
Originally posted by 88 PS190 View PostA boat that cranks and won't catch or cranks and pops then dies when you release the key you look at the kill awitch.
Originally posted by RxMC View PostI had this happen at the ramp on a super beautiful, calm evening. Frustrating and I didn't figure it out until later. It would run as long as the key was in the start position.
So I thought I was out of the woods after fixing the bad battery ground, but experienced the same scenario again and again. Got to my sky club, start my boat, everything fine and after a few minutes the engine suddenly stops and is impossible to start… Next day; same thing. Upon first start, everything goes well then engine dies after a while and impossible to start. So I decided to change the NSS and boat starts again. Was very happy, then after a few minutes the engine dies again… Couldn’t figure out what was happening, then it hit me that the NSS I removed was suspiciously wet. Checked the newly installed one and also wet. Dryer it off and the engine started fine. Turns out my muffler is cracked and is spraying water on the NSS causing it to short thereby killing the engine… Am planning to remove the muffler and replace it with some rust free 3” pipes and marine exhaust. Fixed this muffler a few times already but it seems the cracks always end up coming back, hence removal…
