Old 12-19-2018, 11:11 PM
gwozhog's Avatar
gwozhog gwozhog is offline
Boat: Achilles sg124
Originally Posted by davidstan View Post
Thanks. Found the starboard side plug with a bum shoulder and drained it. Many of the hoses had nothing so i should be good.
Laughed when I read your post. I’m always gimped up too for some reason every time I have to work on my boat. You still need to get the knock sensor on the other side of the engine. It will be n the same location and have a wire plug going to it and need about a 1 inch socket to get it off then you know for sure your block is empty.
I once dated a girl in high shcool and her dad told me I would never amount to anything. He was right.
Old 12-20-2018, 07:51 AM
JohnE's Avatar
JohnE JohnE is offline
Administrator
Boat: XT22
Definitely pull the port side plug, too, as gwozhog said. Don't want to read about a casualty this spring.
Old 12-20-2018, 02:06 PM
Soder's Avatar
Soder Soder is offline
Boat: 2004 X-30 MCX
After you pull the knock sensor and the drain plug on the starboard side, get a 3-inch “drywall” screw and stick it up those holes a few times. The first time I winterized my boat 3 years ago, not much water came out until I pulled out a ton of rust scale from the drain holes. Now I pull those and about a quart to a half gallon comes flooding out of each.
2004 X-30 5.7L MCX
Old 12-20-2018, 04:45 PM
Boat: 2006 X30
I do this - but just flip the plug around and use the post that the knock sensor attaches to on the exterior side of the plug. That’s enough to free up any rust scale flakes and then the water comes flooding out.
