Old 08-14-2019, 08:10 AM
jawest79 jawest79 is offline
Boat: 1998 Prostar 205
Graphics and waxing
Hey all. I just purchased a 1998 Prostar and it needs a little hull restoration. The transom is pretty badly oxidized. Iím going to wet sand the transom and compound the sides of the hull to remove all the oxidation. I also would like to replace the graphics. Should I add the graphics before I apply the wax? Thanks.
Old 08-14-2019, 08:41 AM
LDA6339 LDA6339 is offline
Boat: 2016 Mastercraft X-30 6.0L
Yes
You want the surface as clean and dry as possible to get the best adhesion, this includes no wax of any kind.
2016 X-30 6.0L
"YoU CaNt FiT 4 Rev10's oN a ZFT4"
Lonestar Masterbash
https://www.mastercraft.com/teamtalk...d.php?t=100065
I lead the fight to ban the swimsuit thread, help me bring it back: https://teamtalk.mastercraft.com/sho...58#post1494758
"LDA never saw a thread he couldn't run off the rails"
Old 08-17-2019, 05:12 PM
Thanks! Whatís the best proven method of removing old graphics?
Old 08-17-2019, 10:59 PM
FoggyNogginz's Avatar
FoggyNogginz FoggyNogginz is offline
Boat: 2017 X10
Location: Center Hill Lake, Old Hickory, and Norris Lakes in TN
There are several threads on this forum about this which include pictures and steps to follow. In short, you can remove the vast majority of the graphics with a heat gun, a good hair dryer, and/or some mineral spirits. Always remove all of the wax and glue residue before you apply new graphics. For the best possible shine, use BrianM's method. I've used this exact same strategy to change out the graphics on will pull boats and remove oxidation.
https://teamtalk.mastercraft.com/showthread.php?t=46985
Old 08-18-2019, 08:08 AM
Miss Rita's Avatar
Consider a 3M Stripe Off Wheel to remove vinyl graphics from gelcoat and paint. It might be easier than a heat gun.
Old 08-18-2019, 10:12 AM
Miss Rita's Avatar
Old 08-20-2019, 04:59 PM
Wheelin98TJ's Avatar
Wheelin98TJ Wheelin98TJ is offline
Boat: 2005 XStar
3M stripe off wheel works awesome.
Only thing I would recommend is to use a cordless drill so it does not spin it too fast and damage the gel coat.
Old 08-23-2019, 05:04 PM
Rsims Rsims is offline
Boat: MC Prostar 205 1994 5.7 efi, 1986 Chris Craft 338 commander
I just did it, 1986 name and graphis from my Chris craft, I used Oven cleaner!!! razor blade, it comes right off. then wash and wax... EASY.
Rob
Old 08-24-2019, 10:40 PM
2RLAKE's Avatar
2RLAKE 2RLAKE is offline
Boat: '13 x10 with 6.0 and '93 25th Anniversary Limited Edition
this is the best thread for comprehensive step by step oxidation removal
https://teamtalk.mastercraft.com/sho...dation+removal
Old 10-16-2019, 01:13 AM
danwell danwell is offline
Boat: X25
I used a heat gun and plastic scraper.
2020
