Old 09-15-2019, 11:00 PM
magnum's Avatar
magnum magnum is offline
Boat: Mastercraft X-Star 2006 L18
2006 XSTAR L18 8.1 L throttle Issue?
Does anyone have any ideal what this might be. started running very sluggish and would only get up to about 30mph and then it would start surging if you gave it WOT . you could hear the engine bogging down. It would idle fine. The engine would rev up some when you tried to put in reverse . I read some post on here and guys changed the Throttle position sensor (petitometer ) I ordered one and replaced it on the throttle assy but tried it yesterday and doing the same thing. Any ideals
Mastercraft 06 X-Star 8.1L
Old 09-16-2019, 12:08 PM
magnum's Avatar
Anyone else had this problem
Old 09-16-2019, 12:20 PM
Prostar 190's Avatar
Prostar 190 Prostar 190 is offline
Boat: 1989 Prostar 190. 2008 Prostar 197
This may be a shot in the dark but is your alternator not producing enough charge at certain rpms. If it's not you will not have enough power in the coils to keep up. I had this happen on my old ProStar than again on my Dad's Tahoe. The dealership argued with me when I told them what to check on my Dad's Tahoe. They kept thinking it was a bad fuel pump but came to find out I was right. We stuck an alternator on and the problem went away. Good luck
1989 Prostar 190 351 sold
2008 Prostar 197 LY6
Old 09-17-2019, 11:19 AM
magnum's Avatar
Thanks Will check that out , It seems to idle just fine but when you especially try to put in reverse , it revs up and going forward it just starts to bog down and run real rough
Old 09-22-2019, 10:52 PM
37tr3n5k 37tr3n5k is offline
Boat: 2004 Maristar / 350 MCX
My first go-to when the moror begins to fall on its face is the MAP sensor.
2020
