Old 10-07-2017, 07:50 AM
Jbeams2 Jbeams2 is offline
Boat: 1989 tristar 190
Thanks cmitchell. Great info.
Old 01-22-2018, 02:33 PM
Rugger Rugger is offline
Boat: Malibu 247
Did you build your own surf gates? Or are you using a suction gate?
Weight fairly evenly, but it still helps to cheat with more weight to the surf side.
Old 01-23-2018, 09:29 AM
billboat billboat is offline
Boat: 2000 PS 205
Cmitchell
You wrote that repropping is a must when ballast is added. Is it a must for performance (getting on plane) or to avoid damage to the drive train?
Thanks
Old 01-23-2018, 09:39 AM
Shaun R's Avatar
Shaun R Shaun R is offline
Boat: 2011 X25
You can make a wave big enough to go rope less but that's about it. Surfed a few times behind a Prostar 190 with 800lbs in the back, 400lbs between the observers seat and doghouse, suck gate on the size. Big enough to surf rope less my first time and have some fun. It's not a surf boat by any means but it was fairly easy to setup and let people try something new when the water was bad.
Old 01-23-2018, 09:46 AM
FoggyNogginz's Avatar
FoggyNogginz FoggyNogginz is online now
Boat: 2017 X10
Location: Center Hill Lake, Old Hickory, and Norris Lakes in TN
Originally Posted by billboat View Post
Cmitchell
Thanks
Bill - As we add ballast, it is often optimal to go with a prop that has less pitch and more diameter to improve efficiency and stay within the WOT RPM range. Verify your RPMs at wide open throttle, and then contact OJ or ACME to get their feedback and try out a new prop or two. If you are not able to get to the recommended WOT when under load (or if your boat exceeds this range) then you could damage the engine. However I find that most people change props to optimize performance when pulling or surfing.
surf, surf gate, surfgate, wake shaper, wake surf
