Old 04-05-2019, 04:32 PM
Fowlaction's Avatar
Fowlaction Fowlaction is offline
Boat: 94 Prostar 190
looks great so far!
Cooper
Old 04-06-2019, 11:13 AM
PT 1999 ProStar's Avatar
PT 1999 ProStar PT 1999 ProStar is offline
Boat: Mastercraft ProStar 190 1999 330HP Powerslot - 1st MC 1987 ProStar Current 2012 ProStar 197
Love the blue. It pops when buffed out. Nice job. Looking forward to seeing it completed.
Old 04-06-2019, 09:45 PM
mrm2083 mrm2083 is offline
Boat: 2006 Mastercraft X2
The boat is now out of the water and I have started disassembling the engine. The new long block should be here in a few days.
Unfortunately I stripped two of the Allen bolts that attach the throttle body and one of the bolts attaching the fuel rail. Trying to figure out how to remove them.
I also removed the ecu. Any ideas on how I can clean and repaint it without damaging it?
Old 04-08-2019, 10:13 AM
Ironhorse Ironhorse is offline
Boat: 2008 Mastercraft X14 w/ LY6
Wow the gel turned out great!!
Old 04-12-2019, 08:48 AM
Lots of progress made over the last few days. Picked up the long block and removed the old engine. Removal wasnít easy. First thing we did was try to remove the shaft but there wasnít enough space to fit a normal puller with a center bolt as Iíve seen people on here use. We used one of those sgteering wheel pullers that have four prongs as it was big enough to span across. Then instead of the using a center bolt we just let it rest against the nut of the shaft (which we loosened) and then used the side bolt to tighten it as it pushed the shaft which worked perfectly).
Next we built an a frame out of 4x4s to lift the engine. Once we got it off we put the new long block on a stand and the old engine on the crate that came with the long block.
Old 04-12-2019, 09:19 AM
Maristar210's Avatar
Maristar210 Maristar210 is offline
Boat: paddle
Nice work. Why does my neck hurt?
Old 04-12-2019, 09:24 AM
Haha I post form my iPad and that happens every time. I’m not sure how to fix it
Old 04-20-2019, 10:05 AM
Just received this from gatorstep. What a great company. They were extremely helpful in the ordering process and the flooring was shipped out the next day!
Old 04-20-2019, 10:59 AM
DougP's Avatar
DougP DougP is offline
Boat: 2007 X15 MCX
Just want to thank mrm for taking the time to document this project; it's very interesting to follow.
Old 04-20-2019, 11:17 AM
Blmeanie's Avatar
Blmeanie Blmeanie is offline
Boat: '07 X2
love the blue, have same but mine does not come up over the top and inside, have white interior. I have the back yellow where you have the white. Can't wait to see it all done...
