Old 07-09-2019, 11:56 PM
Speed3guy's Avatar
Speed3guy Speed3guy is offline
Boat: 1987 Mastercraft Prostar 190, 351W
Morse MV1 Shifter broken
1987 Prostar 190, the set screw came loose and I stripped out the splines on the shifter. Anyone know of a source to get parts for this setup? I know this a long shot but after searching I've found nothing for the controls or the shifter itself. Thank you.
Old 07-10-2019, 02:58 PM
88 PS190 88 PS190 is offline
Real fix is replacement - however I have numerous times used green bearing fit loctite to secure things like door handles on antique vehicles when the splines are munched.
Also you can replace the set screw with a dog point set screw - and you can drill a hole the diameter of the dog in the place where the set screw is supposed to engage this will further secure the throttle lever.
Old 07-10-2019, 05:53 PM
Originally Posted by Speed3guy View Post
......... Thank you.
New ones do not exist (generally speaking). There is an MV-2 model that can be modified (nothing huge or ridiculous) to take the place of the MV1. I have info and diagrams, etc. for reference on both models and the mod.
I have a used complete MV-1 control that came off of an 83 model. I bought it as a spare but if you are in need, I can let it go for what I have in it. It's not junk but it's not new. Can be easily restored. I have previously completely gutted one, cleaned it, and put it back together (photos). Fairly straight forward with the diagram. None of these things are cheap (used or MV-2). I think I gave $125 for the one I got a few years ago.
John 14:6
2 Peter 1:38
Old 07-14-2019, 01:42 PM
Speed3guy's Avatar
Thanks for the replies. I will absolutely try that green loctite and longer set screw before i do anything else. I have a trip scheduled from a year ago in two weeks so it is crunch time. In the long run though I am very interested in converting to a newer style that i can get parts for. I'm not too worried about keeping it original as much as being functional and pulling skiers every weekend.
Old 07-16-2019, 04:36 PM
Just make sure to get the Green #609 loctite. bonds .25mm all the way around.
Old 07-21-2019, 11:34 AM
Speed3guy's Avatar
I ended up using an off brand green Permatex, no one around here had green Loctite. Stuff worked great. I also sunk a longer set screw into the handle. Between that and replacing the throttle cable the controls function decent. I had a chance to run the boat this weekend and the shifter is on there solid.
Old 07-22-2019, 09:57 AM
Good stuff - let me know how that Permatex holds up - similarly its really easy for me to find their products locally in autoparts stores - but I know what the Loctite 609 is and use it regularly for all sorts of tasks.
Really once you start to delve into loctite there are a ton of products that are so useful - the #609 green is awesome for fixing loose knobs/handles to their shafts. Obviously red and blue are stuff everyone knows about - but for boats a few other products I strongly recommend having around;
Purple loctite #222 - this is a lower strength version of the normal red/blue - for essentially any bolt on a boat that would be installed dry and or oiled - this stuff is a low strength locker but seals out any corrosion - meaning you can use it with out fear of being unable to remove the fastener and it will seal up the threads and no more rust.
545 hydraulic sealant
567 pipe thread sealant
all good stuff.
Old 11-17-2019, 10:51 AM
Speed3guy's Avatar
This is an older thread but I have an update with the control lever repair. The green Permatex and longer set screw held up the remainder of the season. I did have to adjust the linkage cables which moved the lever forward from the proper position. The lever is now 30 degrees forward when in neutral. Reverse starts at the 12 o clock position and wide open is down by the seat. I'm looking into retrofitting a newer style lever for next season as the mv1 is scarce at best and parts availability is almost zero. And I like putting new stuff on a 30+ year old boat.
Old 11-18-2019, 12:01 PM
Moukie Moukie is offline
Boat: Mastercraft Maristar, 2002, ?
Just curious; were you able to remove your shifter handle after securing with green loctite substitute? I am looking at this option too, but want to be able to remove handle without heat, which may damage my vinyl.
Thanks for your help,
David in SC
Old 11-18-2019, 02:01 PM
You will have a tough time removing with out heat - however in most of these older boats the control drops down once you pull the screws with a bit of trim there. Newer ones may have the shaft go through the vinyl or through the panel.
