Old 01-20-2019, 03:43 PM
KMS KMS is offline
Boat: 2003 Maristar 230VRS---350MCX
Trailer tire pressure???
I've got a trailer tire pressure question for all of you. This actually isn't on my boat trailer, it's on my travel trailer. I just put 4 brand new Goodyear Endurance 225/75/15s on it. They are load range E with a max PSI rating of 80. I have never believed that one should inflate their tires to the max air pressure listed on the side of the tire. I have always inflated the tire based on the load I am carrying.
I have weighed my trailer fully loaded. I have roughly 7000lbs on the axles. Divided by four tires that's 1750lbs per tire. According to Goodyear's inflation chart, to carry that much weight, I should inflate my tires to 35 PSI. That seems absolutely insane to me and I would never think of running a trailer tire that low. This is listed right on Goodyear's website. I checked a couple of other trailer tire manufacturers websites and they all say the same thing.
What do you guys think?
Thanks
Old 01-20-2019, 03:57 PM
lakedrum03's Avatar
lakedrum03 lakedrum03 is offline
Boat: 2003 X-Series MCX
10% less than max pressure. Any tire, anywhere, any time.
Being on a boat that's moving through the water, it's so clear. Everything falls into place in terms of what's important and what's not. - James Taylor
Old 01-20-2019, 04:30 PM
mattison mattison is offline
Boat: 2007 Mastercraft XStar, 5.7
My neighbor experienced severe swaying with his new to him travel trailer when inflated near max pressure. he was told by his dealer that he should be at 35 psi and has not had the problem since
Old 01-21-2019, 08:30 AM
lashburn1's Avatar
lashburn1 lashburn1 is offline
Boat: no Boat
With "Trailer Tires" you should be inflating to the cold Max specs.
On load Range E that will be 80psi.
I live in SoCal too and did quite a bit of Desert trailer trips
The proper tire pressure at all times is the max pressure listed on the side of any trailer tires. Trailer tires are rated for weight capacity and designed to function based on that maximum tire pressure. The tires should be inflated cold, meaning that they should be at max listed psi (in your case 80psi) prior to traveling. The road friction heats up the tires and gives an incorrect reading of max pressure when inflated part way through a trip.
Check your trailer on a scale to get full loaded weight.
Make sure your trailer require E range. But at 7000 loaded that could be the case as Laod D might be maxed.
2015 X20 SS GEN2 6.0
2016 G21 Coastal
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
Old 01-21-2019, 08:33 AM
lashburn1's Avatar
Boat: no Boat
He has another problem, proper tire pressure alone would not "cause" this issue
2016 G21 Coastal
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
Old 01-21-2019, 08:59 AM
lakedrum03's Avatar
Agreed. Sounds like something is out of line and the squishy tires are taking out the push/pull of the misaligned item.
Old 01-21-2019, 09:26 AM
JohnE's Avatar
JohnE JohnE is offline
Administrator
Boat: XT22
What Larry said. With the infamous GY Marathons, I'd inflate to 10 psi over, (75 psi, iirc) based on the speeds I'd go. (Over 65 mph) This was in accordance to the bulletin Goodyear put out with those instructions.
Old 01-21-2019, 11:32 AM
Old 01-21-2019, 03:25 PM
roadster02 roadster02 is offline
Boat: Maybe
Get rid of the expensive, lousy, trailer tires and use LT tires. You will not have any more blowouts or problems, unless you leave the trailer out in the weather, tires exposed to the sun, and unmoved with the tires on the ground for several years. That's my experience with boat trailers, travel trailers, and utility trailers.
Old 01-21-2019, 04:06 PM
JohnE's Avatar
Administrator
Boat: XT22
I never had any problems with the marathons. One former mc employee told me the problems with blowouts were from the stress of the torsion springs when backing up. Not sure if that is true. All other things being equal, I think I prefer her not to have the marathons fortunately I don't anymore
