Is the Clarion marine APX 480m a good amp for $100 or should I go newer? Thanks
Is this a good amp or should I go another direction?
Originally posted by Juiced190 View PostI'm audio illiterate, so I'm not really sure was thinking about powering some tower speakers.Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Originally posted by Juiced190 View PostI haven't bought speakers yet. I saw the amp on craigslist and it looked like a good buy, obviously I have a lot to learn.
Again, I must stress my lack of expertise on the subject. On the other hand, I installed it, it sounds good to my somewhat picky ears, and has held up well.
So the specs for this amp are as follows:
80W × 4 Into 4 Ohms, 20Hz-20kHz @ .05%THD
115W × 4 Into 2 Ohms, 20Hz-20kHz @ .2%THD
Variable Bass Extender, 0-15dB @ 45Hz
Adjustable -12db/Oct. High/Low Pass Crossover, 55Hz-550Hz
So you want to look at the resistance (ohms) of whatever speakers you're considering and the RMS power rating to see if this amp looks like it's a good fit.Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
When buying a new system, start with your speakers, then work backward amps, head unit, wiring, batteries.
If you start in the middle, chances are you are going to end up with wasted components = wasted money and time. A novice especially will buy too small.1991 MariStar 240sc, 454, tower, WetSounds, Krypt and Rockford Fosgate
