Old 09-11-2018, 09:37 PM
AKralk83's Avatar
AKralk83 AKralk83 is offline
Boat: 2001, 205v
Best way to transport a lift
Looking for a lift. Whatís the best way to disassemble and transport on public roads?
Old 09-11-2018, 09:40 PM
MIskiboat MIskiboat is offline
Boat: Prostar
Load as-is on a flatbed landscape trailer. Iíve used my boat trailer to move one as well.
Unless you have to take apart to get in your yard I wouldnít do that.
Then float them to site with barrels or thick foam mats. Also moved one once w two older pontoon boats nose to nose. We just set on front decks of the boats.
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
Cottagergreg put one on a uhual car hauler. I’d measure the dimensions and give that a shot
-Aric
LONE STAR MASTERBASH 2019!!!!!!
https://www.mastercraft.com/teamtalk...d.php?t=100065
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 09-11-2018, 10:31 PM
lakedrum03's Avatar
lakedrum03 lakedrum03 is offline
Boat: 2003 X-Series MCX
+ 1 on what Ben said
Being on a boat that's moving through the water, it's so clear. Everything falls into place in terms of what's important and what's not. - James Taylor
Old 09-11-2018, 10:50 PM
Bongo Bongo is offline
Boat: 2004 MasterCraft 197 TT
Big box truck, if the outer dimensions of the lift are narrower than the biggest box truck you can find.
That said, I've used my scissors style pontoon trailer on a few lifts. Easy to get onto the trailer. A little 'tippy' since the trailer wheelbase width is so narrow, so I keep the center of gravity as low to the ground as I can. And am very slow around corners.
Bongo
Old 09-12-2018, 06:36 AM
AKralk83's Avatar
Boat: 2001, 205v
I was thinking it would be too wide to just set on a trailer. The one Iím looking at is a little over 2hrs away and Iíll be crossing Ohio-Pennsylvania-New York state lines.
Old 09-12-2018, 07:16 AM
jkski jkski is offline
+2 for the landscape trailer. One on you can remove the feet and the width when centered should be about the same as the trailer fenders. I've hauled several this way for 1-1.5 hours without issue.
Strap it down good and away you go.
Old 09-12-2018, 04:25 PM
barefoot's Avatar
barefoot barefoot is offline
Boat: '83 Stars and Stripes
I've transported using a pontoon trailer. Dropped the back legs about a foot off the ground to prevent tipping.
Hello, my name Ryan!
Old 09-12-2018, 05:18 PM
Wheelin98TJ's Avatar
Wheelin98TJ Wheelin98TJ is online now
Boat: 2005 XStar
You can only be 8.5' wide before its considered a wide load.
I'll pull a 10' wide boat lift around the lake roads for a few miles, but I wouldn't go much further than that.
If you lay it on it's side, how wide would it be then?
Old 09-12-2018, 08:07 PM
AKralk83's Avatar
Boat: 2001, 205v
Iím waiting on the other dimensions from the seller. I could only imagine the tickets and fines driving through 2 non home states with a non permitted oversized load.
