  #131
Old 06-28-2018, 03:35 PM
hockeynut99's Avatar
hockeynut99 hockeynut99 is offline
Boat: 1999 MasterCraft ProStar 205 LTR 330HP
have just replaces guages as per thresd....very helpful All is well except bilge and blower don't work ....will look into tonight.Any else have this problem?
Old 06-28-2018, 03:37 PM
jmhjgh jmhjgh is offline
Boat: Mastercraft,205,1996
After some digging the 2002 205V appears to have the upgraded BorgWarner MDC and not the Medallion. Does anyone have a wiring diagram for this unit? I am trying to do a full gauge replacement.
Old 06-29-2018, 10:15 AM
found the problem.......4 pin connector unplugged.
Old 07-13-2018, 10:33 AM
tjrowbot's Avatar
tjrowbot tjrowbot is online now
Boat: 2010 Vride (2000 X5 - SOLD)
Quick question: I do not have pp installed or a GPS speedo. I want to make the change to analog. Do the pilot tubes have enough slack to get to the back of the speedometers? If not, is there a solution other than running new tubes from front to back?
Old 07-13-2018, 01:41 PM
tjrowbot's Avatar
Never mind, I am going with two Faria GPS speedos and making it easy.
Old 07-20-2018, 06:12 AM
lakedawg's Avatar
lakedawg lakedawg is offline
Boat: 2000 X5 "Red Five"
Yes, the tubes will stretch, not an issue. Not that it matters for yours now, LOL!
Another X5 owner!
Lake Dawg
Old 07-22-2018, 04:05 PM
Waiting on my new fuel sending from Centroid....when I get a minute I have to share my conversation with Mary
Old 09-04-2018, 09:11 AM
76S&S's Avatar
76S&S 76S&S is offline
Boat: Not currently in a MC
Well, I finally tackled this on my 02 Star. First, thanks to JeffD for his work in documenting the process and second, thanks to the additional contributors.
I'll see if I can add any value to this thread.
I went with Faria gauges that came with the GPS speedo. The GPS speedo requires a constant 12v and a switched 12v. Coming out of the MMDC 24 pin connector, there is a red and a red with black stripe. The red is switched and the the red with black stripe is where I picked up the constant 12v. I picked up the grey wire for the tach off of the PerfectPass. There was enough wire stuffed behind the kick panel that I was able to pull it through and tap in to the wire. I did have to install an new temp sending unit and run a dedicated wire, the analog gauges will not work with the two wire sending unit found on our motors.
Only thing left for me is a new fuel sending unit and then it will be complete.
2002 X Star
Sold - 76 S&S
Old 09-04-2018, 11:14 AM
D2Dominator D2Dominator is offline
Boat: 2010 X-Star, Indmar LY6
Anyone else run into issues with the thickness of the Dashpanel with the Faria Gauges? I feel they need to be .5 inch shorter to allow correct mounting of the gauges....
Anyone have a solution other than cutting the plastic?
2002 X-Star Indmar 5.7 Vortec Predator (SOLD)
2010 X-STAR Indmar 6.0
Old 09-04-2018, 06:00 PM
petemay121 petemay121 is offline
Boat: Mastercraft, ProStar 190, 2001
Send a message via Skype™ to petemay121
Mine all fitted perfectly. Some that were a bit tight I just got a stanley knife and cut the black stuff as my "wood effect" stuff didn't exactly line up with the thicker black stuff, the black stuff cuts super easy. I lobe having all Faria gauges now that work all the time!
2001 ProStar 190 330hp LTR
2020
