Old 10-27-2015, 10:36 AM
Rochester 220 TBI Rebuild
Going to rebuild my 220 TBI this fall - waiting for parts.
I am really curious to find out what the diaphragm looks like the holds the fuel pressure regulators... I have read on many gm forums that the failure of this diaphragm is a common problem..
I will post pictures as I go - starting by testing fuel pressure.
Old 10-27-2015, 11:06 AM
Old 11-01-2015, 06:12 PM
Well rebuilt it and found that Indmar used some non standard truck TBI parts to tune the TBI... so off to Lake Wisconsin Ski Boats it goes...
25psi??? weird.. https://www.youtube.com/watch?v=TzJp...ature=youtu.be
then after taking tbi apart and putting it back together with a rebuild kit had very low PSI - under 5...
re-used old regulator and spring and got it back to 12 psi - strange again.. you can see in the one pic that the bottom of the regulator is adjustable..
still got the hesitation at 2100 to 2500 - or as gm puts it .. sagging...
Will report back after a pro - looks at it.. not ready to spring for the rhinda software yet...
Old 11-01-2015, 06:13 PM
Oh .. also - indmar raised up the injector unit to let more air in.. they made some nice mods to the stock car TBI Rochester 220...
Old 11-01-2015, 08:39 PM
bret's Avatar
bret bret is online now
It was also set up for the 455 that was on the Impala SS instead of the standard 350 if not mistaken - like 7-10mm larger than the 350 TBI.
Old 11-01-2015, 08:48 PM
Nice work so far Mike. No leaves or shoes in the boat is the sign of a true professional.
Old 11-01-2015, 09:31 PM
SkiWest's Avatar
SkiWest SkiWest is offline
Boat: 1995 Prostar 205
First off, sorry to hear of the continued gremlin to be worked out. Second, being a owner of the same boat/engine, thank you so much for your detailed write ups, pictures, and contributions you make for people like me to reference in the future if needed. I know that's the whole purpose of this forum but I usually pay pretty close attention to your work and thank you for that.
Old 11-02-2015, 02:48 PM
This is great info... might prove better info for the rebuild kit and spring
Old 11-02-2015, 03:02 PM
bochnak bochnak is offline
Boat: 94' Prostar 205 - Indmar 5.7 TBI
What rebuild kit/PN did you use?
On a side note, nice MAP sensor location and hose routing
-Matt
Old 11-02-2015, 03:04 PM
BTW, I have a soda blast cabinet and ultrasonic cleaner with carb solution in case it is not clean enough...LOL.
-Matt
