Old 07-10-2017, 05:50 PM
flyguy570's Avatar
flyguy570 flyguy570 is offline
Boat: 2010 X2
2010 X2 starboard ballast tank removal
Well it was a great holiday week until my bilge filled with water...
Looks like I have a pretty sizable leak in my starboard hard tank and was wondering if anyone has had any luck removing one with out splitting that hull and two if anyone knows if they are still available or easily repaired. Worst case scenario I'll plumb in a fat sac for the rest of the summer, but I kind of like having the hard tank.
Old 07-24-2017, 10:18 PM
Moosecrackers's Avatar
Moosecrackers Moosecrackers is offline
Boat: 2010 X2
Did you ever resolve this problem? I'm curious as to what you found and if you have a solution.
Old 07-25-2017, 06:06 AM
flyguy570's Avatar
Boat: 2010 X2
I started to mess with it an realized that it was going to take more time than I was willing to spend on it mid season. For now I have a fat sac plumbed in place of the hard tank. I plan lo look into it further this winter.
Old 05-05-2018, 08:33 AM
crowmobe2 crowmobe2 is offline
I have the same problem. Did you end up removing the hard tank and replacing it with a bag? Thinking about doing that also.
Old 05-05-2018, 09:33 AM
flyguy570's Avatar
Boat: 2010 X2
I ended up finding the crack and have attempted to weld it back together for now. In the garage it holds water, so weíll see what happens once itís on the lake.
Old 05-05-2018, 09:34 AM
flyguy570's Avatar
Boat: 2010 X2
Word is a replacement tank is about $500 but it takes 20 hrs worth of labor to have it replaced. With the tanks in the 2010s you have to have the hull separated to get the tanks out.
Old 05-05-2018, 09:51 AM
Thanks. Mine is cracked to where I canít repair it and Iím thinking of cutting it out and replacing it with a fat sac. Looking for advice from someone thatís done it before I go tearing into it.
Old 08-30-2018, 10:55 PM
WakeTurbulence WakeTurbulence is offline
Boat: Master craft, X2, 2010, Indmar 350
Reviving this thread
My 2010 X2 STB Tank has started to leak as well. I also have the fly high piggy back system plumed in, the likely culprit, but wanted to know if anyone decided to ditch the tanks and just run custom sacs in their place.
Better/worse?
Old 10-26-2018, 01:37 PM
gwozhog's Avatar
gwozhog gwozhog is offline
Boat: Achilles sg124
Ditch the tanks and plumb in 1100 bags and be done with it.
Old 10-26-2018, 03:13 PM
flyguy570's Avatar
Boat: 2010 X2
I was able to find my leak and fix it. If it had been much worse I would likely have gone the bag route.
