Short story... my 2014 X2 has a very annoying speaker whine from the tower, but none from the interior speakers. Previous owner had stereo work done, including two new ARC Audio KS 300.4 amps, 4 new tower speakers, sub, and a separate equalizer added under the dash.
Played around with grounds, etc. all summer with no fix found. Even tried some cheap filters just to get through the season, no improvement.
Finally after giving up on the season, I brought it to the dealer who just called and said they recommend removing the EQ, replacing both amps with JL ("like they're supposed to be"), and a full new wiring job. Seems excessive, as it otherwise sounds OK. They said the existing amps aren't meant for the boat and don't "have the filters that JL has to eliminate interference from the throttle body".... their cost was $5k+...
In the end, I'm taking it home while I go back to trying to sort it out on my own and research options. I was prepared to drop plenty of coin just be done with it, just not into replacing everything if I don't have to.. The dealers been great otherwise, so this is not a dealer bashing thread, I just think there has to be an easier solution.
Are Arc Audio amps really that bad? Can they really be the issue?
I can get models/part numbers on the other parts if it helps too.
Any input? Can't really buy into the whole burn it down, junk it all, and start over mantra if I don't have to. This isn't Homes On Homes.
Sent from my SM-G960U using Tapatalk
