Old 08-22-2019, 03:42 PM
maniacmikes's Avatar
maniacmikes maniacmikes is offline
Boat: 2018 X-Star
Source for Fastfill ballast impellers?
Anyone source or replace the impellers for the 2018+ quickfill ballast system?
Looking to see if I can get the impellers someplace other than the dealer, but not having much luck finding them.
they look like the standard orange Johson pump impellers - only twice as long. # on them is 08-849P-2
The question is not whether life exists after death, but whether you were alive before death - Osho
Old 08-22-2019, 03:43 PM
Boat: 2018 X-Star
Pic for reference
Old 08-22-2019, 05:37 PM
moosehead's Avatar
moosehead moosehead is online now
Boat: 20 X22 6.2L GDI, '15 X10 6.0L
Not sure if same spec but looks close?
https://www.wakemakers.com/johnson-u...-impeller.html
Old 08-22-2019, 05:48 PM
Boat: 2018 X-Star
Thanks moose, they do look exactly like that - which are the standard Jabsco/Johnson impellers. I had some of those impellers and was going to replace mine, but it wasn't until I pulled them out of the housing that I realized they are about twice as deep...which explains how the fastfill ballast moves so much water so fast.
I have 8 pumps - I think the dealer wants like $50 per impeller - $400 per season on impellers just seems nuts... and these ones have not even made it a season yet and are looking a little beat up.
Old 08-22-2019, 05:58 PM
moosehead's Avatar
I want 8 pumps and 2 pipe.
Sent from my iPhone using Tapatalk Pro
Old 09-21-2020, 03:41 PM
barneyferd's Avatar
barneyferd barneyferd is offline
Boat: Mastercraft X22 2020 6.2L
Was just looking for these, and found them here...
https://www.wakemakers.com/johnson-t...-impeller.html
Trying to confirm, thinking there are 5 of these on an X22?
2020 X22
2018 XT22
2014 Aqua Patio
2003 Malibu Response LXi
2001 Malibu Sunsetter
1978 Ski Supreme
Old 09-21-2020, 04:07 PM
Mystic3D Mystic3D is offline
Boat: 2019 XStar
Those are the correct ones for the fast fill pumps. I ordered an extra set a couple months ago.
Old 09-21-2020, 06:48 PM
bloup101's Avatar
bloup101 bloup101 is online now
Boat: 2015 Mastercraft X20 Ilmor 6.0
You could probably get 2 or 3 seasons out of your impellers depending on how many hours you put on the boat per season.
Old 09-21-2020, 07:17 PM
Boat: 2018 X-Star
The problem is that the fastfill pump housings are a little different than the ballast puppies. The puppies just have a hole where the water enters and exits the pump, but the fastfill pumps have what I would call a grate or some kind of support bracing cast into the hole- the impeller rides over the grate and it really chews up the impeller...it actually kind of cuts it and I have also experienced the impeller getting stuck on that grate and then it won't spin.
Old 09-21-2020, 07:27 PM
bloup101's Avatar
In that case I would probably try to sand polish the grate to remove edges. 2000 grit water sand paper would do the trick.
2020
