  #491
Old 03-06-2014, 09:26 PM
Nick911's Avatar
Nick911 Nick911 is offline
Originally Posted by EA2010 View Post
An hour per day??? How long does it take you to dump/fill each side?
I spent $1,000 to plumb in two 750's in the rear lockers (both tied into the stock lines) with their own pump & switch. Switching sides (dump/fill the stock 250 tanks and the 750 sacs simultaneously) typically takes "one beer" (< 5 mins). The kids usually need a swim to cool off anyway - so the "down time" is not noticed.
How many sessions are you running (per day) that your dump/fill times are an hour?
We ride all day as I take 5-6 weeks vacation and just hang out on the lake, so in a 6 hour day I might take 5-6 sets. Fill times with aftermarket sacs are 7 minutes I think and empty is 9.
Old 03-06-2014, 09:38 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
A grand to plumb them??? Freak, I did mine for $100. You got ripped.
Old 03-06-2014, 09:41 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
Better explain how it cost a grand to plumb in sacs into the stock lines?????? I think it cost me 70 bucks for all the lines and fittings, then probably 400 for sacs?!?! (this is three sacs)
-Aric
LONE STAR MASTERBASH 2019!!!!!!
https://www.mastercraft.com/teamtalk...d.php?t=100065
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 03-06-2014, 09:46 PM
EA2010 EA2010 is offline
Boat: 2012 X-25
No, dude. A grand for the sacs, the pump, the switch and wiring and the additional plumbing and fittings. Labour included.
Old 03-06-2014, 10:02 PM
Boat: 2012 X-25
Oh, and that $1,000 also included a 400lb fly high sac and a tsunami pump as well. So, three fly high sacs, tsunami pump, crossover valve, plumbing lines, fittings, jabsco pump, switch (run next to the throttle), electrical wiring and labour. Not bad.
Old 03-06-2014, 10:15 PM
ap77's Avatar
ap77 ap77 is offline
Boat: 2015 MasterCraft X-20
Did you drill additional holes under the boat to feed the new pumps?
- Andrew
2015 MasterCraft X-20 (current)
2009 MasterCraft X-2 (sold)
Old 03-06-2014, 10:40 PM
Boat: 2012 X-25
That's some good sesh'n. No wonder you're looking for quicker turn-around times.
Old 03-06-2014, 10:43 PM
Boat: 2012 X-25
They used the existing intake/drain hole for the center tank. I can't use my aftermarket system at the same time as the center tank, but I always keep that full ... so it doesn't impact turn around time to switch riders. I can drain the rear hard tank and the locker sac on one side and fill both on the other side simultaneously.
I should add that dumping all ballast (2500-2900lbs) at the end of the day does take about 10 minutes. Time for two beers!
Old 03-07-2014, 12:03 AM
scott023's Avatar
300 worth of sacs, 125 for plumbing. The boat already has pumps, if you piggy backed off factory tanks.
Old 03-07-2014, 12:08 AM
bhanson bhanson is offline
Boat: 2001 X-30 "Surf Edition", LTR, 2079 prop, FAE, straight silencers, 3000# ballast, custom platform, manual surf fin, 1050 Hours and counting
Mastercraft Ad: "To make a wave you have to make a hole in the water." True that. Tabs, gates, etc, are awesome for quickly switching sides, but you still need to make a hole in the water. Pretty sure that with all the attention on surfing that the manufacturers will ultimately figure out how to do both: great pro-level wake, fast switch from goofy/regular.
