Old 09-20-2021, 09:50 AM
prostar205's Avatar
prostar205 prostar205 is online now
Boat: 2002, X30, L-18
Originally Posted by brucemac View Post
Just ordered up custom trailer step pads from Seadek. They're estimating 12 week lead time, so hopefully will have them before spring.
Seadek template/drawing number 34415, which is 6 pieces in total and matched up perfectly to my 2003 MC dual axle trailer.
Looks like the picture below, but I went with black embossed top layer and then black bottom layer.
I like those a lot. Very nice.
Old 09-20-2021, 04:01 PM
brucemac's Avatar
brucemac brucemac is offline
Boat: 2003 Mastercraft X2 MCX
Thanks, me too. Hoping the fenders will polish up nice.
ˇViva 205V!
2003 X2 MCX
Old 09-20-2021, 04:11 PM
brucemac's Avatar
New wheels and tires showed up. Shout out to Pete at tiresplease@gmail.com
ˇViva 205V!
2003 X2 MCX
Old 09-20-2021, 08:26 PM
JohnE's Avatar
JohnE JohnE is offline
Administrator
Boat: XT22
Pete comes through nicely, as usual. Nice job.
Old 09-23-2021, 09:40 AM
brucemac's Avatar
Exciting to see the progress after week 1 and super happy to see how this are shaping up.
ˇViva 205V!
2003 X2 MCX
Old 09-23-2021, 11:02 AM
MC25's Avatar
MC25 MC25 is offline
Boat: 2019 XT22
Can’t wait to see it!!!!
-Aric
LONE STAR MASTERBASH 2021
https://www.lonestarmasterbash.com/
2019 XT22 - Ear Bleeder
2020 Crest 240 SLC Tri Toon - Ear Injurer
Old 09-23-2021, 11:36 AM
waterlogged882's Avatar
No better time than now for seat heating pads. Have the pads installed with the pigtails(s) sticking out (pre-planned location). Wiring can come later. Easy and inexpensive.
John 14:6
2 Peter 1:3–8
Matthew 6:1-4
Old 09-23-2021, 11:45 AM
prostar205's Avatar
That shop and the MasterCraft logo look familiar. Can't wait to see the finished product. Mine's been done for 4 years now and it still looks great.
Old 09-23-2021, 12:12 PM
brucemac's Avatar
You and me both!!!
Do you have a recommendation on a specific product? I saw a post of yours from 2018, but the Amazon link is no longer valid.
Thanks for the advice and referral! Hope you don't mind me using the same logo. Why fix what isn't broke?!
ˇViva 205V!
2003 X2 MCX
Old 09-23-2021, 01:52 PM
Do you have a recommendation on a specific product? I saw a post of yours from 2018, but the SCAmazon link is no longer valid.
Here (or similar) is the same product under a different brand/seller. There are four pads in this kit. I used it and retro-fitted my 93 190; driver - bottom and back, passenger (turned landscape orientation) back and bottom. Works like a champ.
Just figure where you want the wiring to exit the seat location for ease of routing to a switch, then install with that in mind.
Any seat that raises, work the orientation of the pad to where the pig tail will be close to the hinge point for raising the seat.
Easy peasy.
I will say this as a tip... if you (or the installer) run a wire(s) across an area of the seat cover (sometimes near the exit point), use an Exacto knife (or similar) to cut a small trench or slot in the foam for the wire to lay in. Makes it a much nicer fit. Nothing complicated at all. A serrated knife blade works best when cutting foam...makes it a breeze and very nice edges. A straight edge, not so much, particularly on larger cuts. I use an electric bread knife with the serrated edge blade for large (thick) cuts.
For the best install, make sure the installer lays in a thin layer or pad between the foam and the vinyl cover (regardless of the heat pad). Some installers do, some do not.
Regardless of the cuts in the foam, the pads will find a home and settle in nicely once they are installed; especially with the thin padding between them and the seat cover. You'll never know they are there until you turn them on. I wallow all over my passenger's seat with my knees, etc...these pads are tough. No problems at all for me.
John 14:6
2 Peter 1:3–8
Matthew 6:1-4
2020
