Old 05-29-2020, 01:51 PM
Barker Barker is offline
Boat: 2019 NXT20
1/4" npt barb fitting for oil change
My '19 NXT with 5000 MPI has already had 2 dealer oil changes. I am getting ready to do my first oil change at home.
I know I need the 1/4" NPT barbed fitting for the drain hose out of the rear transom hole. I assume male or female end depends on which pump you are using?
I was going to use the Harbor Freight style pump, would I need a double barb fitting to connect the pump to the engine oil drain hose? (after I warmed up the engine)
I would want to grab my oil analysis sample midway through the draining.
After sucking out all the oil with the pump, do I cap it back up or do let it sit for a while and see if more oil drains naturally?
Thanks!
'19 5000MPI in NXT
Old 05-29-2020, 04:35 PM
jmhjgh jmhjgh is offline
Boat: Mastercraft,205,1996
I think you will struggle with that style pump. I would recommend a vacuum pump similar to a MityVac (fluid extractor). It is more money, but far more useful.
2020
