Old 03-23-2019, 06:26 PM
lukejackson1 lukejackson1 is offline
Boat: 2006 Mastercraft X-Star
2006 MCX Crank Position Sensor
I have a 2006 XStar with the 350 MCX Vortec that has been throwing the Crank Position Sensor code for 3 months. I was told by my mechanic it could be replaced with a sensor from autozone as opposed to spending $230 from Mastercraft. Replaced the sensor but still get s check engine light and alarm almost as soon as i put the boat in gear, it runs fine in neutral. Last go round at the river it threw the code and we plugged a diagnostic tool in and cleared it, i immediately brought the boat home and sent the computer to be tested and the same Crank Position Sensor code was still on the computer. Anyone had this problem as well?
Old 03-23-2019, 06:53 PM
sand2snow22's Avatar
Boat: X24
You have to set the timing. Using diacomm and above 1,200 RPM's twist the distributor until the cam angle is 705
Old 03-23-2019, 06:57 PM
Is that something i can do? And is that done on the computer or on the engine itself? I had the computer sent and tested at OBD Diagnostics and he cleared the codes.
Old 03-23-2019, 07:00 PM
Boat: X24
You gotta have diacomm software program, plug the ecm into diacomm. Also, did you check the connection at the crank position sensor. It's pretty low in the bilge so it's prone to water and oil which can make the connection less than desirable.
Old 03-23-2019, 07:01 PM
Boat: X24
If the timing is off you can get a lot of random codes. Crank Position Sensor being one of them..
Old 03-23-2019, 07:05 PM
I looked at the connection pretty good, but it could be faulty wiring as well. I attached a picture of the sensor
Old 03-23-2019, 09:04 PM
gwozhog's Avatar
gwozhog gwozhog is offline
Boat: Achilles sg124
Do you have the autozone part number for what you bought?
I once dated a girl in high shcool and her dad told me I would never amount to anything. He was right.
Old 03-24-2019, 01:03 AM
Yes it was a Delphi Sensor part #SS10125
Old 03-28-2019, 12:17 PM
tryathlete tryathlete is offline
Boat: 2008 Mastercraft 197TT
$48 and change
2006, mcx, vortec, xstar
