Old 05-22-2014, 10:02 PM
ELB ELB is offline
Boat: 2006 MC X-30
X-30 won't restart after engine is warm..
Please help. 2006 x-30 MCX (excelent condition and low time) will not restart after being shut off once the engine warms up. It turns over and kinda wants to start but will not fire up. Occasionally if I pump the throttle it will start and once it's started it runs great until its shut off again. I thought it was the fuel pump but after I put on a new MC module today (ouch) the same problem occurred. Fuel seems to be getting to the throttle body because I can smell fuel after turning it over several times. If I let it sit for an hour if fires right up. Ignition? Sencor? Any ideas? Thanks for your help in advance.
Old 05-22-2014, 10:19 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
What is the condition of your plugs, wires, distributor cap, and rotor? Try the simple things first. Also check for vacuum leaks around the intake and valve covers. Check the PCV valve and the hose that runs to it.
We defy the mafia!
Old 05-22-2014, 10:20 PM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
Vapor lock?
-Mike
Old 05-23-2014, 12:41 AM
Boat: 2014 X-25 6.2 Ilmore
My boat did this (the LTR-earier version of the MCX)—acted just like vapor lock, but being port injected, I couldn't figure out how/why. Believe it or not it was the thermostat. I had a 140 from the factory that was causing a rich issue. Once I switched to a 160, no issues.
Old 05-23-2014, 03:35 AM
Possibly ECT going bad.
https://www.youtube.com/watch?v=wFHWpgHMAvY
https://www.youtube.com/watch?v=i2Kd0VQWw1o
Tim
Old 05-23-2014, 07:37 AM
FourFourty's Avatar
Boat: 2020 XStar
^ that is what I was thinking as well. That, or the intake air temp sensor.
Old 05-23-2014, 10:47 AM
TeamAllen TeamAllen is offline
Boat: Tigé, 2150, 1997, Merc EFI
Does it have a schrader valve on the fuel rail? if so, check the fuel pressure using a fuel pressure gauge when this occurs.
Old 05-23-2014, 11:58 AM
All the MC MCXs have a schrader valve on the fuel rail.
Tim
Old 05-23-2014, 05:44 PM
Great! If it's vapor lock, it's my understanding when you you are experiencing the non start issue, you can depress the valve and air(vapor) will come out. Use caution since the engine is at temperature and fuel might/will come out. A pressure gauge is still the correct way to check.
Old 05-23-2014, 07:59 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
My LTR did same and this fixed my hot start issue as well.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
coolant sensor, hot start issue, ignition, mcx, relay, sensor, x-30
