Old 05-06-2021, 08:19 AM
Shawnymac11 Shawnymac11 is offline
Boat: 1992 Mastercraft Prostar 190
New Bilge Pump
I've dug deep into archives and found great information on replacing the original bilge pump. I have not found the exact answer on the wiring.
Old yellow/black mayfair pump had brown/black wires
Old Float switch had two grey wires
How do I connect the new Rule pump that has a built in float?
Rule Pump has:
Brown Wire-Automatic
Brown w/ white stripe-Manual Override
Black- the negative wire
I just can't figure out how to go from (factory) 4 wires coming from the dash, to three wires at the new pump. Any help would be appreciated.
Old 05-15-2021, 10:31 PM
williamsatown's Avatar
williamsatown williamsatown is offline
Boat: No
I had the same issue.
I went with the manual Rule pump and the float switch. That way I didnít have to change the wiring. I actually completed that change out about an hour ago.
Let me know how you fixed your wiring if you made the change to the three wire. Just curious
Old 05-15-2021, 10:59 PM
MLA MLA is offline
Boat: pontoon
The old float B+ goes to the new pump brown
Old pump brown goes to new pump brown/wht
black to black
Old 05-15-2021, 11:00 PM
MLA MLA is offline
Boat: pontoon
black to black
Old 05-15-2021, 11:03 PM
Boat: No
Do you just cap the second ground wire that was with the original float?
Old 05-15-2021, 11:39 PM
MLA MLA is offline
Boat: pontoon
Stand alone floats are typically only 2 wires, no ground. Battery B+ in, then out when water raises the float.
auto, bilge, float, rule, switch
2020
