Old 04-06-2021, 03:38 AM
Richy Richy is offline
Boat: 2010 x30 ss
Originally Posted by Rhob88 View Post
the center tab is on the factory switch an the gen 1 tabs are on a different switch , so no the gen 1 tabs work perfectly , just my center tab has failed
I have the same installation. A switch for surfs tabs and a switch for central trim. But when I press the central trim it activates the two surfs tabs up or down. I found nothing abnormal, no fuse blown.
I ordered a wire tracker so I could track the connection from the actuator.
If I canít find it, Iíll plug the actuator directly into the switch, without the computer and the dash screen...
Old 04-10-2021, 07:39 AM
Boat: 2010 x30 ss
Hi,
Actuator trim tab engine is working but it seems that the lenco control box has a problem. Control box 30231.
So I’m going to connect the center trim switch directly with the center trim tab without going through the control box.
Old 04-10-2021, 08:57 AM
Rhob88 Rhob88 is offline
Boat: 1994 mastercraft 205
Never thought of that , good luck , keep us posted on the outcome
Old 04-21-2021, 04:53 PM
Boat: 2010 x30 ss
Hello,
OK I did it.
With a relay I was able to keep the original switch. The trim works again but I forgot that this same switch is also used to retract the surf tabs. To fully retract the surfs tabs it is necessary to do it with computer, not so bad...
Although this was not the problem, check all ground wires before the modification, all my wires were loose,
[/IMG][/url]
2020
