Old 11-18-2018, 08:37 PM
joelevy joelevy is offline
Boat: 2007 X45, 8.1L
Threading wires in ZFT3 (2007 x45)
Anyone have any tips on threading some more wires up through the ZFT3 tower? I'd like to add an accessory (power for a gopro) and have had a devil of a time threading a wire through the tower openings.
Old 11-19-2018, 11:28 PM
bloup101's Avatar
bloup101 bloup101 is offline
Boat: 2015 Mastercraft X20 Ilmor 6.0
I've seen pros use treaded fishing line and compressed air or vacuum to feed the line in the passage ways. Something like this https://youtu.be/c6y5gyldRDE
Old 11-20-2018, 02:14 AM
Thatís amazing. Will be trying that trick for sure
Old 11-20-2018, 07:54 AM
jgraham37128 jgraham37128 is offline
Boat: 2016 Mastercraft X23
Exactly how you pull fiber too.
Old 04-01-2019, 08:16 AM
37tr3n5k 37tr3n5k is offline
Boat: 2004 Maristar / 350 MCX
Instead of compressed air, use a shop vac to suck the string thru. I threaded new wires in about ten minutes.
Old 04-01-2019, 09:04 AM
Double D's Avatar
Double D Double D is online now
Boat: 2008 X14, w/ LY6 400HP w/ 1.22 Ratio Tran
I just did this on my ZFT3. I used a spring loaded pincher device to go from speaker to speaker, and from the port side speaker to the hole at the break point. The direction you go matters. Then added a plug around the break point, and used a 'fish tape' to get from the upper hole down to the next break point near the bow. The last section that ties into the bow I used a thick wire because the fish tape didn't like the last bend. The hardest part is where the rubber grommets are so whenever you have that, you should enter there. I did not pull out the grommets.
2008 MasterCraft X14, LY6, 400 HP
1994 MasterCraft ProStar 205 (SOLD)
