Old 08-15-2017, 01:23 AM
Flexx's Avatar
Flexx Flexx is offline
Boat: 2006 Mastercraft X2
I can get this for cheap if i buy it a car spare part, right?
Thanks for the advise..
I had no chance to check the codes till now.
Greets from Germany,
Felix
Old 08-15-2017, 02:09 AM
Flexx's Avatar
I see if it is bad when the engine runs, and i disconnect the plug, right?
Felix
Old 08-15-2017, 06:54 AM
Need to find out which ECU you have before I can say what you need to pull codes with. Do not use a paper clip until you know for sure which ECU. You could damage it by doing so.
-Tim
Old 08-15-2017, 07:12 AM
Flexx's Avatar
Thanks!
The ECU is mounted in front of the Dash behind the folding wall?
Felix
Old 08-15-2017, 08:09 AM
They are generally mount on the back of the motor; near where the motor bolts to the transmission.
MEFI ECU Types. You probably have a MEFI 4.
There maybe a cover over it. This is a MEFI 5
This is the cover.
-Tim
Old 08-15-2017, 08:14 AM
Flexx's Avatar
Thank you very much!
Will check it later when im on the dock.
Wich ones can be read out with the "paper-clip-method"?
Felix
Old 08-15-2017, 09:02 AM
MEFI 1-4 can be read with the paper clip method.
http://www.offshoreonly.com/forums/d...%241-00-a.html
You can remove the please excuse my English in your sig; your English is far better then my German!!!
-Tim
Old 08-15-2017, 09:15 AM
Flexx's Avatar
I removed it
Got a break from work to inspect the ECU unit.
I think youre quiet right with MEFI 4, so i could read it out as the instruction offers?
Felix
Old 08-15-2017, 10:41 AM
Yes, MEFI 4 and those instructions will work for you.
-Tim
Old 08-15-2017, 11:00 AM
Flexx's Avatar
Tim.. thanks!
I will get out the codes (if available) as soon as i get the LED
The diagnostic lead ist next to the ECM in the same Harness?
Felix
check, code, ecm, ecu, mcx
