  #621
Old 11-14-2018, 11:48 AM
93Prostar190's Avatar
Originally Posted by Krw1225 View Post
Posted a thread in the audio section, but figured Id ask here as well, what have you all used when upgrading the amps for the stereo system in your x-14s?
http://www.mastercraft.com/teamtalk/...ad.php?t=99621
I am totally happy with the JL Audio amps.
Ski in snow, ski in water, and always have fun!
2008 Prostar 214 MCX
1995 Prostar 190 "Evil Minion"
"Do you have Flake on that boat?"
Old 11-14-2018, 02:04 PM
Krw1225 Krw1225 is offline
Boat: 2008 X-14, 40th Anniversary Edition, MCX w/ Powerslot
Agreed, but my original JL Audio amps have switches that are starting to go bad (ie. the speakers cut in and out, and my brother-in law verified its not the speaker). So are you saying you would just get new JL Audio amps, if so which ones? Or were you thinking to just leave them stock, not realizing mine are going out?
Old 11-16-2018, 08:30 PM
markw61 markw61 is offline
Boat: None, yet
Originally Posted by JohnE View Post
I could swear that on my Boatmate trailer, the trailer didn't extend more than an inch or two past the bow when folded. Maybe that would be an option?
Just a follow up on length of trailers. I may be wrong, but it appears that MC made a change to the trailer around 2011 or 2012. The old design which appears to be the design that is about 22 feet has a forward keel support to help identify it. The new design has longer inner bunks that go much further forward and replace the need for the forward keel support. From my eye, it appears that this design is several inches shorter, maybe up to 5 inches or so. I attached photos showing the different MC Designs and a Boatmate just for comparison. I'm hoping that MC did reduce the overall length with the newer design. I hope this helps someone else as well.
Old 11-17-2018, 04:03 PM
zsqure's Avatar
zsqure zsqure is offline
Boat: MasterCraft X-14, '09 Blue
Don't know if that is a realistic comparison. Seems you are pitting 14 dd against 14 vd. Different engine placements add another variable to the mix. Need more input.
https://badges.fuelly.com/images/smallsig-us/302328.png
1988 prostar 190 SOLD
2001 Prostar 209 SOLD
Old 11-17-2018, 07:00 PM
JohnE's Avatar
JohnE JohnE is offline
Administrator
Boat: XT22
I'd triple check to see if that is the problem. Something as simple as a loose wire, or loose ground, to the amp will make the speakers cut in and out. You could change out the amps, and unknowingly "solve" the loose wire problem, and think the amp was the culprit. Why don't you remove the amps, and bench test them in as simple a way as connecting a pair of cheap speakers to them? I had a similar problem in my 197 back in '07. I really doubt that the switches in the amp are on the fritz. And I'd hate to see you throw money away if they aren't.
Old 01-25-2019, 03:00 PM
mcnorthwest's Avatar
mcnorthwest mcnorthwest is offline
Boat: ProStar 214V, 2009 Indmar 6.0L
Nav Light Not Working
My tower nav light is not working (see pics). Before I start chasing wiring I was hoping to replace the bulb to see if that solves it. Problem is that I can't seem to get the lens cover off...any advice. Does it screw off or this their some sort of release that I'm not seeing?
Old 01-25-2019, 03:31 PM
Double D's Avatar
Double D Double D is online now
Boat: 2008 X14, w/ LY6 400HP w/ 1.22 Ratio Tran
I was told it screws off, but have not removed mine yet.
2008 MasterCraft X14, LY6, 400 HP
1994 MasterCraft ProStar 205 (SOLD)
Old 01-25-2019, 04:00 PM
dmbeck's Avatar
dmbeck dmbeck is offline
Boat: 1998 Prostar 205 (Sold), 2006 x15 w/ mcx
It does screw off, just gently push down and turn counter clockwise. If you have to remove the entire housing then there are screws under the clear lens.
Old 01-25-2019, 04:36 PM
Thanks, I'll give it a go.
Old 01-26-2019, 07:13 AM
mike koen's Avatar
mike koen mike koen is offline
Boat: mastercraft x-14 2008 mcx
The clear lense is threaded.
If she don't shine , she ain't mine
