Old 05-02-2017, 09:14 PM
#snatchattack's Avatar
#snatchattack #snatchattack is offline
Boat: 2000 X-Star
Battery Draining Issues? Anyone?
I have a 2000 XStar and I am having serious battery draining issues. Went through too many batteries in my opinion so far. The positive has been disconnected for a little bit, while we were working on the new stereo. The positive was left disconnected and the negative was still connected. Came back to complete the stereo install a few weeks later (I work alot) and the battery was dead as could be. First thought was bad battery, but installed a new battery (was suppose to be added as a second battery, but that is on hold) the positive was disconnected and when connecting the negative, it sparked. Second thought is a bad ground... Is that possible? Any ideas, thoughts, comments, suggestions?
Old 05-02-2017, 09:44 PM
MLA MLA is offline
Boat: pontoon
Ok, if a battery has nothing connected to one post, doesnt matter which one, and it goes "dead" there is not a drain issue, but a battery issue. A battery cant be drained if its not connected.
With an audio amp wired up, there is typically a spark when trying to connect a cable. Thats due to the CAPs charging up inside the amp. Does not indicate an unwanted draw though.
Old 05-02-2017, 10:11 PM
Boat: 2000 X-Star
Thanks. I plan on trying to leave the positive disconnected for a few days on this new battery and see if it drains again. I did forget to mention we added a battery switch a few weeks ago too, not sure if there could be an issue there. I am no electrical person, I usually try to avoid it at all cost. I had a draining issue before I added the battery switch, but only when both cable were connected.
Old 05-02-2017, 10:48 PM
Ever read a Chilton's manual? The first step in ALL repairs, according to them is "Disconnect the negative cable from the battery".
Do you have a multi-meter? Set it to measure current and connect it to one of the cables and its post. Make sure it's able to handle at least 10A and if it isn't designed for that much, get one that has a clamp for larger loads. Read the current and start pulling fuses, one at a time. When you get to the one that draws the most, find out why. If you find that the draw is more than a few milli-amps and the only thing connected is the alternator, have it checked- the bridge rectifier can fail and cause this. It's a good time to think about upgrading the alternator's charging capability- that case can now be upgraded to about 115Amps according to the owner of a shop that I use for alternators and starters.
I never recommend replacing when a rebuild can be done- there's nothing to change and it's a direct fit.
Old 05-03-2017, 06:52 AM
If you have a good shop that can do the rebuild. We've got a local shop but he probably has a 35% failure rate on his rebuilds.
-Tim
Old 05-03-2017, 07:20 AM
How are they still in business?
Old 05-03-2017, 08:49 AM
Part of the "Unsolved Mysteries" series.
-Tim
Old 05-03-2017, 03:53 PM
Boat: 2000 X-Star
No I have not ever read that manual I will keep it in mind! I think we can get a multi-meter. So I will try that test ^^, when I get a chance. If that is the case I will have to find a place to rebuild the alternator. Thanks for the info!
Old 05-03-2017, 06:24 PM
j2shay's Avatar
j2shay j2shay is offline
Boat: 2000 prostar 190 330 ltr
I am sure Jim n will know far more than anyone here, but I have a 2000 prostar 190 that had a problem of the power draining when not in use. The original owner put in a perko switch and never had issues since. I have not had any issues and turn it off when not in use. Hope this helps and might be worth a try if you can't isolate the problem any other way. Good luck!
Joel
Old 05-03-2017, 10:43 PM
Boat: 2000 X-Star
Joel
We just put a perko switch in it and it still drained the battery. Hopefully I get to run it tomorrow and see what it does a few days after.
battery, electrical
