Old 08-26-2017, 07:08 AM
4stauffers 4stauffers is offline
2014 6.2 x25 -- Bad Motor
I am in the process of purchasing a used x25 -- upon inspection the boat would not start, oil had water and the spark plugs were rusted - codes show it overheated 2x once at 190 and once at 220. I realize the motor is shot. This does have the salt water package. Any ideas on what a new long block would cost?
Old 08-26-2017, 08:45 AM
CruisinGA's Avatar
Boat: '01 X9 330HP
Sounds like the head gasket blew or the heads cracked. Might be rebuildable depending on how bad internal rust is.
Here's a marine 6.2, not sure if it is exactly the same configuration that Ilmor uses.
http://www.michiganmotorz.com/377ci-...ent-p-545.html
Bailey
'02 X-9
Lake Blue Ridge
Old 08-26-2017, 09:05 AM
Illmor Motor
It is an Ilmor 6.2 Salt Water series
Old 08-26-2017, 09:07 AM
Thanks -- IS it better to just buy new motor or rebuild? I do want it to be reliable.
Old 08-26-2017, 09:18 AM
CruisinGA's Avatar
Boat: '01 X9 330HP
My preference is to buy new if available.
I would call Michigan Motorz and see if they know if that 6.2 block is the same that Ilmor uses. Then all you have to do is swap over the intake/exhaust manifolds and accessories and reinstall.
Bailey
'02 X-9
Lake Blue Ridge
Old 08-26-2017, 10:34 AM
any indication why the motor overheated?
Old 08-26-2017, 11:37 AM
1redTA's Avatar
1redTA 1redTA is offline
190 and 220 are not overheated, engines run this temp all the time, especially with the closed cooling system.
The oil and water is definitely an issue and would pull the heads and inspect for head gasket damage, trueness of the head and check the exhaust manifolds to makes sure that isn't another issue.
1981 MasterCraft
19' Skier 351W PowerSlot
Old 08-26-2017, 12:23 PM
Shaun R's Avatar
Shaun R Shaun R is online now
Boat: 2011 X25
Water in the oil points to an exhaust manifold issue, coolant in the oil points to an internal issue. I would drain the oil and do a compression test before you write it off as a total loss.
Old 08-26-2017, 12:30 PM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
That is not the engine ilmor uses - you need the gen 6 376ci engine. This one I believe is just a stroked 350
Old 08-26-2017, 01:09 PM
Shaun R's Avatar
Boat: 2011 X25
Ilmor also goes out of their way with internal components and would rather rebuild one of their setups then buy an off the shelf motor.
https://www.youtube.com/watch?v=b5Hsgbewtl4
6.2, engine, motor, rebuild
