Old 04-27-2021, 12:06 AM
prostar205's Avatar
Boat: 2002, X30, L-18
Low Voltage Alarm (10.3V)
I am in need of some electrical advice. This past winter I replaced both of my batteries, added the Blue Seas battery switch and ACR and added the ProMariner 20A battery charger.
When I de-winterized, I keep getting the low voltage alarm with the volt gauge reading around 10V. My Perfect Pass is also seeing 10.3V.
I checked voltage at both idle and at 1,500-2,000 rpm starting at the alternator, then starter, then battery switch, then ACR, then both batteries - all good with measurements around 13.3 at idle and 14.4v at higher rpm.
Then I figure its the volt gauge itself so I replaced it with a brand new one. That's not the problem.
Then I replace the MMDC (that was not cheap) but that's not the problem.
I am measuring 12.98v between the positive and negative blocks under the helm not matter at what engine rpm is at.
I'm at a loss for where the Perfect Pass and volt gauge are getting their readings from.
Can anyone provide some ideas of where to look next?
The boat is a 2002 X-30 with the Medallion gauges.
Old 04-27-2021, 09:01 AM
prostar205's Avatar
Admins - please delete this thread. It's a duplicate of one I already posted.
2020
