Old 12-30-2009, 10:09 AM
kiteklan kiteklan is offline
Boat: Mastercraft Prostar 190 1997 ,with steyr 236 HP Diesel
1997 Complete Renovation of Prostar 190 with Steyr 236 Diesel Engine
Hello,I will post my renovation experince under this threat.
I am renovating a mastercraft prostar 190 1997 model.
Started with a mistreated hull and without an engine.
I had bought a steyr 236 HP diesel engine with 4200RPM and 2:1 ZF 45 transmission.
Engine weighs 380kg with the transmission.
We built the treyler on our own with Knott axels/parts and I and U profiles.
Please tell me some hints or your opinions.
AFTER SANDPAPER AND POLISH
Old 12-30-2009, 10:15 AM
Diesel Engine and some accessories
4200 RPM 236 Horse Power Steyr 236 Engine 380 kg with the transmission
I have one propeller right now with a diameter 36cm but I guess it will not be enough,my plan is to lunch the boat with this propeller and get the draft and waterline with the engine,I have no idea about its draft and waterline and the total weight that is why ordering a propeller will not be wise without a certain measurement.
I about the trailer ,rims are from one of my old car (1989 Probe GT),I will try to get it lower and adjust the axels to the center of weight when I will finish the boat.
It is not easy to this work in Turkey since original parts are not easy to find and expensive.
Platform after some work
Interior Condition Chaos
Old 12-30-2009, 10:16 AM
Insturment Panel
Instrument Panel,
Original panel was in very bad condition ,we had covered it Fiberglass and make new holes for guages.
I was thinking to use Volkswagen Marine 225 V6 but it was above my budget.Steyr 236 is a light weight and powerfull engine but its dimensions are bigger then orginal mastercraft engines.
Does anyone has an idea how much an orignal mastercraft engine weighs(total weight with transmission? and RPM ,Transmission ratio?
There are more pictures on the my website
Old 12-30-2009, 10:21 AM
DemolitionMan's Avatar
DemolitionMan DemolitionMan is offline
Boat: 2008 Pro Star 197 TT #58 of 100
Looking Good.
Automatic doors make me feel like a Jedi
Old 12-30-2009, 10:26 AM
I am really interested in how that diesel performs in the boat.
Definitely making progress. Keep up the good work!
Email - tiresplease@gmail.com
Old 12-30-2009, 10:52 AM
Name Of The Boat
Today we name the boat:
Old 12-30-2009, 10:54 AM
thanks ,I am trying to finish it in 2 weeks.
Old 12-30-2009, 01:07 PM
rholmes's Avatar
rholmes rholmes is offline
Boat: Mastercraft, Maristar 210, 351, bought in '07 with 227 original hours.
The motor should weigh 227-272 kilograms fully dressed. A transmission was likely originally a hurth 1:1 and would have weighed probably in the neighborhood of 68 kilos. Operating RPM range would have been about 600rpm to a max of 4600-5000rpm. These are just rough figures, nothing exact. maybe someone else can help out with exact numbers.
If it's a penny for your thoughts & you give me your two cents, what happens to the other penny? Taxes, the democrats tax everything!!
1990 Maristar 210... Sold
In the market though...
Old 12-30-2009, 03:52 PM
jasonba1 jasonba1 is offline
Boat: supra comp, supra labrisa,malibu wakesetter x30 now x45
awesome project
Old 12-30-2009, 04:10 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT-1
Just a guess... but I think you will be disappointed with the boats performance if you go to all the trouble of making that engine combination fit. It looks like it is only a four cylinder engine in the photo.
Need LT-1 parts?
89058397 (pump outlet side)
diesel engine, renovation, repair, steyr
2020
