Go Back   TeamTalk > General MasterCraft Topics > Tow Vehicles
Old 02-12-2017, 09:29 AM
Miss Rita's Avatar
Miss Rita Miss Rita is online now
used Suburbans
I'm starting VERY early shopping to replace my '02 Tahoe with a newer Suburban, looking at something 3-5 years old.
The Tahoe has 3.73 gears to go along with the four speed AT. It seems that most of the newer vehicles have 3.42 gears (or even 3.08) and a 6-speed tranny.
Is it correct to assume that this is the new standard spec for a towing package?
Old 02-12-2017, 09:54 AM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: Searching
Yes, lots of trucks have that setup now. My 2011 F-350 has a 6spd with 3.73.
Old 02-12-2017, 09:59 AM
fstaslp fstaslp is offline
Boat: 1999 Mastercraft Maristar 230VRS
DO NOT get the 3.08 gears in the GM with the 6 speed. I had it in my 2014 Sierra CC. While it did get the job done, it was rated for like 6200 lbs. Made me nervous with my 1999 230VRS. We then towed it with the touareg, rated for 7700 lbs and it did much better.
I will get another truck and I will be on the look out for the highest numerical gear I can find after working with the 3.08. Also, the truck was tuned and ran well, but I always yearned for better gears.
1999 Maristar 230 VRS
Old 02-12-2017, 01:21 PM
1redTA's Avatar
1redTA 1redTA is offline
the 4.03 first gear in the 6l80 with the 3.08 equals a ratio of 12.41 while the 3.06 first in the 4l60with the 3.73 equals 11.41.
The 6l80 trucks don't need a higher numerically rear end though it would be more fun
1981 MasterCraft
19' Skier 351W PowerSlot
Old 02-12-2017, 01:42 PM
Maybe not needed but I with the two extra gears, the truck would be constantly shifting towing on grades. First gear wasn't really the problem.
Old 02-16-2017, 12:14 PM
Forrest-X45's Avatar
Forrest-X45 Forrest-X45 is offline
Boat: X-45
I believe the Burbs with the 5.3L come with the 6L60 or 65 and the 6L80 only comes behind the 6.2L in the Escalades and Denali's. The Burbs didn't come the six speed trans until 2009 model year while the Escalades and Denali's had the six speed from 2007. So if you can find a 2007-2009 Burb with the four speed trans you can get the 3.42 or 3.73 ratio but once the six speeds were introduced in 2009 you could only get 3.08's. There could be 3.42's out there but my guess would be they are hard to find used.
2008 X-45 Pro Tour Red and White
Old 02-16-2017, 04:09 PM
orbeamlb's Avatar
orbeamlb orbeamlb is offline
Boat: 1988 ProStar 200, w/Mercury 2.5L 200hp XRi Outboard
My 2011 Burb has the heavy duty towing package with the 5.3 & 3.42 rear end. Trans is 6sp with manual mode.
Mike B
Old 02-17-2017, 09:19 AM
Miss Rita's Avatar
Thanks for the replies. It makes sense that with the addition of a 6-speed tranny the differential ratio could be numerically lower. I'm so used to seeing the 3.73 number for the past 30 years that the new lower ratios caught me off guard
Old 02-18-2017, 07:01 AM
Don't be caught off guard....stick with the 3.73:1 or taller.
John 14:6
Old 05-07-2017, 03:55 PM
SamT SamT is offline
Boat: 5.7 comp ski Velvet drive trans
My wife has an 09 Tahoe with 6spd and 3.42 if I remember right when we bought it (new in 09) most of the nicer package ones with tow package had 3.42. I think if it has 20" wheels it probably has 3.42 in that year. I'm not sure if that follows tru through the years.
It pulls fine in the 5-6k range, but it really sucks if you hook onto something that catches wind. It's a lot better than the work pickups I've had in the same time frame with 3.08 gears and same motor and trans. It stops a load good with the wide 20's too and has reasonably stiff rear springs. I think the Tahoe squats less since the hitch is closer to the rear axle.
